dflesburg
Jun 14 2009, 03:36 PM
pedal up and lots of pedal pressure but...
engine revs and nothing happens like its not in gear.
I know its in gear because I can feel the gears with the shifter.
the car responds like the clutch is pressed in all the time.
The pedal is stiff as hell and the cable is tight.
The bearing arm moves. But when I let the clutch out with the motor off and the car in gear, the car rolls .
what could that be?
914Sixer
Jun 14 2009, 03:40 PM
When was the last time your replaced the plastic ballcup in the release bearing arm?
dflesburg
Jun 14 2009, 04:17 PM
release bearing arm has tension
dkjens
Jun 14 2009, 05:13 PM
Check your CV joints, one may have let go. The driver side outer let go on mine and it felt exactly that way. When I took it apart I expected to find a pile of metal pieces, but everything was intact, including the cage. Somehow the cage had spun and allowed the axle to spin. The inner race had a nasty scar on one edge.
messix
Jun 14 2009, 05:19 PM
QUOTE(dflesburg @ Jun 14 2009, 02:36 PM)
what could that be?
lots of things, the marcel could have broken. thats the center hub of the clutch. the input shaft of the tranny could have broke. the pinon shaft could be a goner.
dflesburg
Jun 14 2009, 05:47 PM
update:
pass side axle turns backward in reverse, forward in forward gears.
so you know, this is a 914-6 conversion with 914-s stub axles...
more help please...
Millerwelds
Jun 14 2009, 06:05 PM
I'm fairly new to all this but I just swapped out my clutch and transmission and went through those systems. It almost sounds like you have the clutch cable to tight and the release bearing is doing it's job even when you have the clutch pedal up. Assuming a six is like a four with the 901 trans in place you need about a 1/2 to 3/4 free play at the clutch pedal (grab the pedal and pull towards the driver seat). Unless it is something bigger that requires dropping the trans. Might as well losen the clutch cable first and see if that helps.
dflesburg
Jun 14 2009, 06:07 PM
then why would the axle turn but not the wheel.
messix
Jun 14 2009, 06:08 PM
QUOTE(dflesburg @ Jun 14 2009, 04:47 PM)
update:
more help please...
thats broken!
does the stub turn too?
Cap'n Krusty
Because you have a busted CV joint, or the bolts that hold it tight to the stub axle ..........................
The Cap'n
dflesburg
Jun 14 2009, 06:12 PM
cv joint
Millerwelds
Jun 14 2009, 06:52 PM
QUOTE(dflesburg @ Jun 14 2009, 05:07 PM)
You did not mention that the wheel did not turn......just how the axle turned. You have just answered your question....CV.
dflesburg
Jun 15 2009, 08:38 PM
how about if all my bolts came loose holding my outer cv assembly...
messix
Jun 15 2009, 09:20 PM
dflesburg
Jun 15 2009, 09:22 PM
laugh it up...
bet nobody ever told you that you have a few screws loose.
messix
Jun 15 2009, 09:27 PM
nope.... a couple missing yes!
locktight!
Dr Evil
Jun 15 2009, 10:39 PM
Your axle should NEVER move without the wheels moving.
Joe Bob
Jun 15 2009, 10:57 PM
BTDT, left the Tee Shirt and walked home nekkid.....live and learn. CVs are designed to be the weak link. Cheaper than trannies or clutches....
EdwardBlume
Jun 16 2009, 12:05 AM
I lost my half shaft doing 70 on 280! It sounded like popcorn though...
