Given that I have a decent old school drill press, not a mill.
I need to drill a 42mm hole into an air cleaner base that is about 1/2 inch thick.
There is already a 38mm hole.
So, I just need to bore it out, centered, by 4mm.
What tool would you suggest?
I have a air grinder and a few carbide end mills that I use in that...but if I used that it would be freehand...
I am good, and might be able to do it...but I could also make a decent mass out of it.
I would rather make/get a tool that would work to mill a nice clean hole.
Rich
