championgt1
Jun 15 2009, 01:44 PM
I just got new sway bar bushings and there is not a slit in them. I have replaced sway bar bushings before that had a slit cut in them so you could just "pop" them over the bar without removing the bar from the car. So my question is could you just cut a slit in them or do you need to remove the sway bar completly?
6freak
Jun 15 2009, 04:24 PM
I think i would remove the bar Jack...Let me know if you need a hand
Jun 15 2009, 04:48 PM
If i recall correctly, the two black rubber bushings had a slit in them when i mounted mine ...
Andy
championgt1
Jun 15 2009, 07:13 PM
That's what I thought. These bushings I have are weltmeisters and do not have a slit. I don't see how you get them over the end of the sway bar to slide them on all the way.
championgt1
Jun 15 2009, 09:07 PM
OK I am an idiot. These do have the slits in them. Somebody slap me!
