championgt1
Jun 15 2009, 07:39 PM
On a three port fuel pump what wire hooks to the + and- ?There is a black/red and a brown. I want to make sure these are hooked up correct and I suck at reading wiring diagrams.
neil30076
Jun 15 2009, 07:46 PM
QUOTE(championgt1 @ Jun 15 2009, 06:39 PM)
red/black is hot ( +ve) - brown is (-ve) ground
championgt1
Jun 15 2009, 07:50 PM
That is what I needed to know. Thanks!
Joe Bob
Jun 15 2009, 10:14 PM
Yup...brown be ground. Don't you have a test light or a Fluke?
Yer always gonna need one of them....or an Uncle Fester and a light bulb....
Joe Ricard
Jun 16 2009, 05:51 AM
Meter won't do much good if wiring diagrams are foreign to him.
But if the motor spins backwards then reverse the leads.
Katmanken
Jun 16 2009, 08:38 AM
Joe,
Isn't it hard for most mortals to see into a sealed pump to see if it's spinning backwards?
Brown is always ground (aka negative) in these cars.
rhodyguy
Jun 16 2009, 10:16 AM
running jack?
k
championgt1
Jun 16 2009, 10:19 AM
QUOTE(rhodyguy @ Jun 16 2009, 09:16 AM)
running jack?
k
It is all plumbed and ready to go. Hit the key and the fuel pump is not running. Changed the relay with a known good one and still nothing. Hooked the pump power directly to the battery and it pumps fuel no problem. Not sure were to go from here.
Spoke
Jun 16 2009, 10:47 AM
There is a fuse for the fuel pump relay on the relay board in the engine compartment. Is the fuse ok?
Katmanken
Jun 16 2009, 11:35 AM
1.8 with Ljet fuel injection??
Pump won't run if the air flap of the fuel injection doesn't move.
Cap'n Krusty
Jun 16 2009, 11:40 AM
Try changing BOTH fuel system related relays and cleaning the fuse and its contacts on the relay board. The Cap'n
championgt1
Jun 16 2009, 12:20 PM
QUOTE(Cap'n Krusty @ Jun 16 2009, 10:40 AM)
Will do.
It is a 2.0 djet
