Hi everyone, I have been woking on this 72 914 1.7 Fi for about a month now. When i bought the car the guy said that the right head "Cyl 4,3" needed some work. The car started, but would barely run. No throttle responce, wont idle much. I towed the car home, started cleaning things in the engine compartment, attempted to set the timing, but the fuel hose cracked and started spraying fuel in my face. I replaced all the fuel lines in the engine compartment, replaced a couple of vaccuum lines, cleaned the throttle body, Painted a few things, then adjusted the valves. When i adjusted the valves, I found that cyl 4 intake valve was pulled into the head to where there is no more adjustment. I know i need to fix this problem before the engine will run correctly, but i need to drive this car a couple of miles to my mechanic "might have to tow if all else fails".
I put everything back together, checked the point gap, started the engine and set the timing, but the engine runs like crap. Better than when i bought it, but still crap. I could tell something was wrong, so i started pulling plug wires to see which cylinders were firing. found that 1 and 3 are firing good, but 2 and 4 are doing nothing. When i tried to start the car with just 2 and 4 hooked up, i just got a small backfire into the intake. Plug wires are in correct sequence. After running i checked exhaust pipes and 2,4 were barely warm, 1,3 were hot. anyone have an idea of what i need to look at next? Thanks
