QUOTE(SLITS @ Jun 17 2009, 02:42 PM)
QUOTE(ghuff @ Jun 17 2009, 03:26 PM)
CIS is crap.
Given a choice between carbs, cis, and EFI.
EFI, carbs then CIS as a last resort.
Fuel distributors are expensive, injectors for cis are expensive. Both are super prone to getting crapped up by small particles and CIS running problems will make you want to stab babies.
Personally I would go with standalone EFI running off head temp sensor(s)
Fuel distributors rarely fail. Failure is mainly leaks or a stuck center piston from sitting for years with fuel in them. Yep, $500 for a rebuilt one or 3-4 cans of brake cleaner @ $2.00 can to clean them up. Oh yeah, and the cost of compressed air.
Mechanical injectors rarely fail. Failure of these units would be an internal broken return spring or fouling from fuel sitting in them for years. $60 each new or a couple of cans of brake cleaner to clean them or pay someone about $25-$30 to clean them.
Filters are for keeping the small particles out of the distributor and injectors just like your EFI system. Additionally, you have the leakage failure of electric injectors which are plastic toppped metal cylinders (unless late model), the potential failure of the solenoid in the injector itself and broken pintles.
Now, spit that one out again.
Really? 30+ year old mechanical distributors that have had 30+ years worth of fuel with an unknown moisture content floating through them rarely fail?
Been there done that, you have a 50/50 chance of that crappy distributor coming clean with brake clean and compressed air.
You are right, they do not outright fail but the control plunger metering slits get shit up, and when you decide to pull it apart and rebuild it you have a 50/50 chance of it working and running proper once together even if you do it clean room style and ensure that every mating surface is flat.
Mechanical injectors do in fact fail, the springs get weak, they leak and the mesh filter screens get full of crap because they are about 30 years old.
Also CIS injectors last time I checked were 100$ a pop for watercooled VW's. A fuel distributor? 300$ for a watercooled VW.
At this point you could have batch fire standalone fuel injection with a wideband o2 sensor. Not some shitty mechanical fuel injection that is constantly pissing on the back of your intake valves and never quite runs right.
Filters do a great job over 30+ years, apparnetly which is why I have taken apart and cleaned more than my share of CIS distributors and injectors only to have a car run immeasurably better when retrofitted with EFI or even carbs.
CIS also restricts airflow with counterpressure by fuel to avoid the metering plate flying up and in return restricts the path of airflow and you have poor throttle response.
This is not 1970, or 1980. CIS is crap, EFI or carbs are a better way to go. The only good thing CIS can do is CIS injectors rock at atomizing fuel.
Now spit that one out again.
