QUOTE(bare 1 @ Jun 17 2009, 08:37 PM)
this is maybe 35 degrees off. 180 out ? HMMMM Did it run backwards???
Sounds to me like it's retarded. As you time the engine you'll turn the dizzy some number of degrees. Not quite 35 though.
With just about everything stated above. Start with the basics. Clean it up, check all of the vacuum hoses and replace as necessary and then get the timing right. Toss in a new set of points while you're at it. Then I'd do a valve adjustment.
I had one 914 that wouldn't stay timed at all until I replaced the dizzy. It kept losing dwell angle because the points rubbing block kept wearing away. I never found out the real root cause because I had plenty of dizzies laying around at the time. Tossed in a replacement and it worked great.
