A few weeks ago I had a lifter noise coming from my drivers side head, SBC 350. I pulled the valve cover to find lots of play in #1 intake, barely moving when I started it. I adjusted it and fount the adjustment was wayyyy off compared to the others. So I couldent wait, I drained the coolant, pulled the dist, manifold, and sure as Sh*t I found the lifter missing .050 of metal on the bottom with a small hole in it. It wouldn't pump up. So I headed down to the local AP store and get a new lifter for $7.99. I spot checked a few others and they were all ok.
So, all back together, get it running set the timing, change the oil, ( FYI, ran the oil thru a magnet to catch any metal, nothing found) Runs good and strong like the good ole days.
Now the oil pressure is progressivly getting lower. Was 60psi at start, with 20psi as it warms up at idle, 50 at cruse. Now 55 at start, gets as low as 10 at idle, 40 to 45 at cruse. I did switch to mobil 1 5w-30, then 10W-30 on the last 2 changes.
working from past experience, low oil press is never a good thing.
I know the cam is defective and needs replacement, I expect to replace the oil pump, hopefully just polish the crank and a new set of bearings?
If that's it, pistions and rings OK, I will probally keep the steel heads and spend my $ on a roller cam and lifters. I already have roller rockers, and some decient heads.
For those of you guys who know the history of my engine better than me, it suposidly had 416 hp on the Dyno and close to $6500.00 in build cost. So it is worth keeping it instead of a new crate motor.
Plus did I mention the govener (wife) is keeping an eye on the budget.
I have talked to a few guys here in Sequim tell me there are no shops on the Olympic pennisula worth using.
Any recomendations on machine shops in the PNW? someone mentioned Action Auto parts on 99 near edmonds. I did find a guy in PA, he just assembles and farms out his machining to a guy in Tacoma.
Feel free to shoot me thoughts, opinons, ideas and experiences. I'll post picts as I start the project, it will at least give me a chace to detail the engine compartment.
Thanks for any input
Tony
