QUOTE(PanelBilly @ Jun 19 2009, 04:20 PM)
I'm eliminating the relay board in the engine bay and oesn't that have the relay for the pump? Would I be better off running wire from the main breaker? Also I'm using carbs, so I'll need to get a lower pressure pump and re-using the connector won't be important.
I've got a 75 parts car and have looked at the access panel. I just hated cutting a hole in the fresh paint. (Well its old paint now, but still "virgin" to me).
Any other good ideas for the pump location?
Yes it does have the relay, but you can hard wire the pump to switched power.
The beauty of a relay or switch in the fuel pump power is that in case of a loss of fire (engine running) the pump would shut off.
You can accomplish this with a switch that is accuated by oil pressure. It will have NC & NO contacts. NC side is wired thru the starter so the pump has power on start and NO closes for power during run due to oil pressure. If OP is lost the fuel pump gets cut off.
