First off i know why i am breaking "this pin" my shifter is not adjusted to stop so it over throws taking out the "pin" on hard shifts
so don't run me through the wringer for not having my shifter adjusted
....But.... back to "this pin"
(i will try to describe it from a vegetable merchandiser's perspective)
Under the tranny there is a plastic boot held on by farmer's bale tightener(sic)
inside this plastic boot is a 13mm set screw- which has a propensity to back out-
though not a fault of its own
Which holds a "cup"
the "cup" is designed to hold a "ball"
the ball is attached to the shaft
By the ....infamous....PIN
and it is the damn pin that keeps breaking
(it is truly my belief that the kraut that designed this shifter was not only smoking bc bud...but he was eating to many brownies to boot)
does any one have a solution, aside from the adjustment on shifter, for this pin
or should i just split for the beefy Jwest solution....
and in the interm make a cottered solid pin for the time being
......and....adjust my shifter
