EyeTrip
Jun 20 2009, 02:31 AM
Can I weld this up or use this on a street stock setup?
914Sixer
Jun 20 2009, 07:38 AM
Not sure if the torque on the the bar would break the weld. Then again, it may last forever. It is worth a try.
aircooledtechguy
Jun 20 2009, 09:40 AM
I'd be more concerned about the weld ruining the sway bar's springiness (is that even a word??
) It's the heat treatment that makes a sway bar different from just a long, bent piece of iron. . .
Katmanken
Jun 20 2009, 09:50 AM
It's toast.....
Spring steel is notch sensitive meaning a crack WILL form in the notch...
Feeling lucky as to when it lets go and your handling changes al the sudden?????????
I agree with the above, spring steel is heat treated to be a spring, meaning it wil break (snap) if you try to bend it too much or at too sharp a radius...
Welding will turn that into a nice bendable section.........
EyeTrip
Jun 20 2009, 08:32 PM
Thanks for the input fellas.
6freak
Jun 25 2009, 09:10 AM
QUOTE(aircooledtechguy @ Jun 20 2009, 08:40 AM)
TORQUEAFACATION....lmao
