QUOTE(J P Stein @ Jun 20 2009, 12:52 PM)
Some data off the top of my head, but not exactly what you want.
The scavenge side is un-regulated as far as pressure is concerned. A fella told me some years back that he rigged a pressure gauge on the scavenge side to check it. He got up to something over 160 psi, IIRC, on cold sart-up.
The pressure side moves something like 55 to 65 liters per minute depending on the pump. I get up to 10 bar on my pressure gauge for a couple seconds on cold start-up.....rpm is unknown but probably under 4K. The scavenge side is 1.6 tmes as capable volume wise.
I haven't a clue about cfm on the fan.
HTH.
Holy crap - 160 psi? I would have guessed a lot less since it's a straight shot back into the tank, less the bypass valve at the oil filter. One odd thing I noticed, correct me if wrong on this, but the Porsche auxilary thermostat "shows" full pressure to the aux cooler even when closed (cold), it just doesn't allow flow until open. I just got some hoses crimped at napa - I hope they did that right! 160, sheesh.
The reason for asking is for auxilary oil cooler with electric fan
