QUOTE(SirAndy @ Jun 22 2009, 11:54 AM)
QUOTE(76-914 @ Jun 22 2009, 11:18 AM)
That is your version. Here is mine. It is a patch placed over, not someone elses patch, rather treated metal which had deteriorated to the point that it would no longer hold the gasket in place. In my humble opinion, this is a matter of function not appearance. And if it were, it is covered by the gasket anyway. Beleive it or not there are many of us who are not concourse people and could give a rats ass about such trivial matters. When finished, my 914 shall be sound, reliable (for a 914), nice to look at and FUN. If the next owner of wants to weld up the channels, fine. I, for one, don't plan to invest a shit load of $$$$ in a 914. A 356;maybe. Don't get me wrong Andy, I enjoy this project, this site and the fellowship here but I do think that some people tend to go overboard on this machines. Besides, I'm 58 and would like to be driving this thing when I die; not still working on it
I wasn't even talking to you. I was commenting on the first post in this thread.
Your car, do what you want. And if you post on a public forum, chances are someone is going to disagree with you. Yes, what i posted was my opinion.
I'm a firm believer in "do it once, do it right". Your mileage may vary.
If you look at my car, you'll notice it's probably as far from concourse as one can be.
Still, if time and money permits, i like to do things right, like replace rotten metal with new metal instead of covering it up with plastic.
Andy
Function here, not form Andy. I do agree with you, where metal replacement needs to be done it does need to be done. However, in this case it is a pro vs con. There is nice paint on this car, and the rust it has is cosmetic and can be encapsulated yet for a long time before worrying about replacing metal.
I also am not sure aside from a rotisserie how you would replace the sheetmetal in the corner box area. I would like to hear how, since it's underneath the hood and if you simply grind and weld from the top, you can't grind the weld inside clean enough and coat it so it does not rot back through. Likely it would involve cutting into the fenders as well, forming that channel ,possibly into the lower a pillar where it forms the door jamb? Fortunately just about 1/4 inch back is through into there and sculpting it together por patch will work for years. Rust is fine when it is entirely encapsulated and the flake/pit has been cleaned well enough. That is the key, encapsulated on both sides to prevent spread. It is not even going to be visible unless you take a mirror behind the hood arm where it mounts. You can't rot out of plastic when it's encapsulated, you know?
There is the catch 22 in dealing with unibody cars, can you seal it back from the inside and or underneath? Because Moisture *will* get in there. Just the humid maryland air here will take minor rust and quickly make it swiss cheese pitting that is through.
Really, in this case it is doing it right.I do have a welder, a decent lincoln that does flux and gas. I actually seam welded my old scirocco with flux, that was a complete learning car. I also expirimented with por-15, and all sorts of stuff.
I prepared the rear quarter panel of that car well enough so that rattle can paint with clear and rattle can primer has stuck on it for years without anything creeping underneath.
Anyways, at about 18-20 hours into this, while some paint was drying I sectioned up my battery tray and started cleaning the pitted up hell hole and frame area in there.
I would like to weld metal in for the .5" hole on the inside about 2" above the hell hole but below the battery tray (No clue why it rotted through here, it was not covered in crap.) But it too will be patched, sealed and treated until in a few years metal can be welded in.
I know this is more like bondo than metal work -- but in this case it is properly done bondo that is lightyears ahead of most 914's and lightyears ahead of just letting it continue to rot. At this point it can all be encapsulated for a *long* time.
