619]For Sale: Numerous parts from a '74 2.0 litre.
Well.... I didn’t get these cleaned out by Christmas...
So.... If you want anything... better move fast.
As soon as I get my act together, all the big stuff is going to the scrap dealer.
No Reasonable Offer Refused!!
Set 914 Shop Manuals on Microfiche B.O.
Set Minilite style wheels with tires, B.O.
Gone for scrap!
Left Exterior door handle, $35 OBO.
Chrome rear bumper $50 OBO. (possibly spoken for)
Rear struts, B.O.
Gone for scrap!
Two rear Targa top latches, $25 ea OBO.
Spare D-Jet FI computer, $35 OBO.
Side shifter shift linkage complete B.O.
Side Shifter engine mount bar, B.O.
Stinger style exhaust $25 OBO. (possibly spoken for)
Headlight and motor assemblies, left and right, B.O.
Engine lid torsion bars.
Left Tail light fixture with lens, and 2 without.
Headlight switch $40
Emergency Flasher switch. $20
1 tach and speedo gauge panel.
1 trip odo reset drive (I sold the speedo already)
Viton push rod tube seals (O-rings)
CV joint gaskets
Oil pump gasket
Oil Pump (original Porsche)
Valve cover gaskets
Half Shafts (2 good, 2 questionable)
Rear trunk lid hinges
Rear Trunk Lid latches (2)
Rear Window glass
Upper part of steering column
Engine lid hinge bracket
3 Seat belts
Gone for scrap!
Fuel tank sending unit
Fuel Injectors
Handbrake cable
Clutch cable
Front trunk release cable and handle with lock
Engine tin screws (new)
Pedal assembly
Plywood backing for pedals
Jack Point reinforcing repair plate (new)
Jack point plugs
Riviera alloy wheel with tire
Lug bolts
Front bumper ('74 Nader style with bumps) (possibly spoken for)
Gone for scrap!
1 torsion bar
Threaded rubber bump stops for engine lid (2)
Set of ignition wires with ends, and set of just screw-on ends
Fuse block
Fuse block cover
Misc relays
Gone for scrap!
Master cylinder... probably original 17 mm
Brake fluid reservoir
Bumper "dog bones"
Oil pressure sending unit
Porsche Technical Specifications booklet for the 914 (inspection
specifications and wear limits)
Side Marker Light and Lenses (Left Side Only)
Many small parts too numerous to list.
Contact me with your needs and for pix.
All large items pick up only in Lancaster, CA
