QUOTE(brant @ Mar 5 2004, 11:11 AM)
ditto on the hard, flat, level surface. a carpenters framing square is a nce tool for the measurements. measure all four corners before you start. a little goes a long way when you start turning the adjusters(haynes p. 101, fig 7.3) out. you need to roll the car back and forth a bit each time you make an adjustment to settle the car in.
kevin
