First of all - great site! It is nice to see all of the fine 914 work and excellent advice in one place. I have been a fan of the 914 since I was a kid and finally bought one.
1974 Zambezi Green 2.0...2 owners, 36K Miles. Had not run for 6 years, but the engine was free. Drained gas, charged battery, new oil, oil filter, fuel filter, new plugs & wires, checked point gap, adjusted valves. It fired up with a majestic roar and ran decently. It is far from perfect, but it is complete and unmolested. There are some hell hole issues and some rust under the rocker panel covers.
My goal is to get the engine running perfectly before dropping it to repair the rust. Hopefully, I will only have to drop the engine once if I do it this way.
The car runs very well, but I still have a consistent high idle (about 2500 RPM). I am running factory fuel injection. The problem persists even after completing all of the following:
- new plugs & wires
- new air cleaner
- inspected points and set gap to .016
- replaced all vacuum lines (bought kit from AA) & fittings, including the "stacked vacuum fitting"
- replaced intake runner boots & intake gaskets
- checked dwell and found it to be well within limits
- set timing IAW Haynes Manual
I just tried to adjust the idle speed using the screw on the air intake...it had very little effect on idle speed even at the adjustment limits.
Any help would be greatly appreciated. Thanks
