QUOTE(underthetire @ Jun 21 2009, 06:54 PM)
QUOTE(RJMII @ Jun 21 2009, 07:23 PM)
The bolt on solution from Eric.
kit for early car, that uses stock brakes:
http://www.pmbperformance.com/catalog/item...565/1355581.htmthen when you're ready to change your front rotors, you'll need to get the redrilled front rotors:
http://www.pmbperformance.com/catalog/item...565/1355570.htmAs long as you don't warp the rotors, you should be good for a few years. =o)
Still need spacers for the 16" phone dials. They are the late offset.
Try the 21 mm spacers , I got a set that I mocked up , put on one of my 7 X 15 52mm offset Phonies , ( it has 215 / 60 / 15 tires on them , came with the wheels ) cleared my driver's side rear , disconnected the spring / strut , put on a spare strut with no spring , jacked it up as far as the strut allowed , still didn't rub , not a lot of room left , but did not rub when turned . This was on a arm that is being converted to 5 lug , so I put on rotor , spacer , wheel , no problems. No fender pulling , although a PO had ground / cut the lip down which wouldn't be real hard to do if needed.
Check them out , they sometimes can be had cheap.
Jaxdream
