blitZ
Jun 21 2009, 06:51 PM
I've had some sporadic fuel delivery issues. My car has stalled and had trouble starting restarting. Today was the worst. It died. I pulled off to the side of the road and could not hear the fuel pump while turning the key. Tried a different fuse, nothing. Had a bud tow me home. Tried it a few hours later and it started right up.
Is my fuel pump failing? It would seem like if it failed that would be it. Is there something else I should be looking at?
Stock Djet.
gasman
Jun 21 2009, 07:11 PM
My 76 had fuel pump issues....truned out to be the fuel pump ground wire that goes to a push on ground tab under the gas tank on the drivers side. Mine came loose and gave me intermittant pump problems. Use a test gauge and jiggle the ground wire to see if it's ok......
r_towle
Jun 21 2009, 07:52 PM
And the dirty old relay.
Replace the fuel pump relay with a headlight relay...even better...but a new one.
Rich
cwpeden
Jun 21 2009, 09:06 PM
How clean is your gas tank?
I had a similar problem and it was the screen on the gas tank suction screen.
check this post for pic:
http://www.914world.com/bbs2/index.php?sho...090&hl=tank
blitZ
Jun 21 2009, 09:48 PM
QUOTE(r_towle @ Jun 21 2009, 09:52 PM)
Rich
Where is the fuel pump relay, on the relay board?
jt914-6
Jun 21 2009, 09:53 PM
Yes, that is where it is. There is a fuel pump fuse next to it also. Check the fuse for corrosion and contact as well as the relay......
blitZ
Jun 22 2009, 06:45 AM
QUOTE(jt914-6 @ Jun 21 2009, 11:53 PM)
Probably the only relay I haven't replaced. I think I'll try that first.
Thanks to all...
70Sixter
Jun 22 2009, 01:08 PM
Have never looked at a 914 FI fuel pump, but my 911 pump demonstrated sporadic failures for no apparent reason.
I analyzed the problem after replacement and found the gasket between the electric side and the pumping side had a small leak.
The fuel would leak into the electrical side from the pump side and kill the connection. After draining for a few hours everything would appear to be fine.
I always was thankful that a spark did not ignite an explosion.
