Full Version: Headlite Not working
Scott Carlberg
So the other nite out on 580 in Livermore, I hit this bump in the road quite hard,
and my driver-side headlite went out.
I checked the fuse and it was fine, even changing the fuses for R & L headlites.
Still no lite.
Does this mean the headlite just blew?
Or, is there something else I should check before I toss it?
Sylvannia Silver Star.... that I have NOT had all that long, just over a year!!! ohmy.gif
Joe Bob
Then if it STILL don't work, check the connection inside the ceramic/[lastic thingy that plugs into the back of the lamp....
$.05 please....
QUOTE(Scott Carlberg @ Mar 5 2004, 12:07 PM)
does it still go up/down? if not, the relay fell out. ask me how i know wink.gif
take the top cover off and check the plug and make sure it didn't slide of the spades. ask me how i know wink.gif
Andy
Scott Carlberg
QUOTE(mikez @ Mar 5 2004, 12:37 PM)
$.05 please....
Dave_Darling
Remember, there are four fuses for each headlight. Left low beam, left high beam, right low beam, right high beam. Is it both low and high that is gone on yours?
I'd guess fuse, or bulb. Wiring is next on "the list". Grounds are unlikely, as the one light will ground through the other causing it to come on but be very dim.
--DD
TheCabinetmaker
QUOTE(Scott Carlberg @ Mar 5 2004, 03:15 PM)
$.05 please....
Invision Power Board © 2001-2024 Invision Power Services, Inc.
