Gigamight
Jun 25 2009, 10:29 PM
This engine came with my car as a donor/ transplant. I can't find any mechanics around that have the slightest idea what it is. I also am wondering if there is a way to try and get it to crank without being in the car. I am assuming that the starter gets mounted body side, and so there is no place to mount it to the engine itself? Am I correct, or is there a trick to it?
Zundfolge
Jun 25 2009, 10:34 PM
I may be wrong but that looks a lot like the 2.0l motor in mine.EDIT Just as I noticed I was wrong (the spark plugs are too vertical for a 2.0) Jake Raby posts ... BTW, ANYTHING he tells you is going to be correct.
The starter mounts on the transmission.
You can put a socket on the big nut inside the squirrel cage (see the alternator? follow the belt to the fan on the crankshaft) turn it clockwise I believe ... better wait for confirmation here from someone that is more sure. (been a couple years since I did a valve adjustment and turned the motor by hand)
Jake Raby
Jun 25 2009, 10:36 PM
Easy..
Small plenum, small runners and Yellow top injectors.
Its a 1.7
rick 918-S
Jun 25 2009, 11:28 PM
Put it on a pallet, bolt up the transaxle and starter, jump the starter.
Cap'n Krusty
Jun 25 2009, 11:50 PM
'73 1.7. The Cap'n
