machina
Mar 5 2004, 02:23 PM
finally got the motor up onto the stand.
I can turn the motor be the fan but then I noticed that the whole damn crank moves in and out like 5mm.
"is that bad?"
dr
thesey914
Mar 5 2004, 02:54 PM
Uh yeah. the end play is supposed to be measured and the correct amount of shims added, I think 5mm is a bit large IIRC it should be >3mm
banderson
Mar 5 2004, 03:03 PM
You must not have a flywheel on it. The Flywheel holds the crank back. IIRC, the spec was something like .003-.005" . very small
machina
Mar 5 2004, 03:13 PM
yes, the flywheel is removed.
I am splitting the case anyway, just wondering if the movement indicates anything foreboding.
thanks,
dr
Jake Raby
Mar 5 2004, 03:43 PM
without the flywheel, thats pretty much normal...
