silverteener
Jun 28 2009, 02:13 PM
I've been having this issue with my turn signals. Sometimes they would work and sometimes they didn't
I thought maybe it was the switch so I swapped it out with another one I have but it didn't help. Actually they don't work at all now. I cleaned the metal on the steering wheel that contacts the turn signal switch. I checked my fuses and they are all good. I did notice that if I had the turn signal on with the key on the side marker light will stay on. Any suggestions on what to do next. I'm at a loss!
thanks
Scott
inschool
Jun 28 2009, 04:19 PM
Have you checked for power at the turn signal/flasher unit?
ericread
Jun 29 2009, 01:22 PM
How about providing the year of the car. Different year 914's have different steering wheel controls.
Split the problem in half. Start with either the circuit between the battery and the relay or the relay to the lights.
My advice: Start with the relay to light circuit. Drop the relay board (under the dash) and check the fittment of the relays. Then with the car off, temporarily run a positive line from the battery to the positive side of the trace (relay output). Check to see if your signals light. If not, time to check grounds and circuit continuiety.
However, I would bet that the problem is on the other side of the relay. I just like to check the easy to test part first so that I know I'm not wasting my time.
Eric
jt914-6
Jun 29 2009, 05:22 PM
Does the emergency flasher work? On some 914's the flasher and turn signal use the same relay.
914's are designed to have the park lights come on when the signal switch is depressed left or right when the key is off or removed. Just the side that is depressed will come on (left lights on if depressed left) Designed for parking on narrow streets in Europe to let the car be seen better when parked.....
silverteener
Jun 29 2009, 07:29 PM
Did I mention I hate electrical problems! It's a 72. my flashers will still work but no turn signals. I'll start tracing things tonight. I did mention I hate electrical right??
Thanks
Scott
silverteener
Jun 29 2009, 08:39 PM
I ran a jumper to #49 that the relay plugs into. It made my fuel pump run for a couple seconds but my turn signals still didn't work.
I also found the ground under the dash and it was tight. I'm not sure where to go from here. Did I mention I hate electrical
904svo
Jun 29 2009, 09:05 PM
Pull up the EM brake handle with the key on the Brake lamp in the gauge should work, if not remove the gas gauge and ground the black/white wire on the brake light bulb socket, if this works (lamp flashes) the black/white wire to the emergency switch (49A) is not connected or open. The black/green wire which is also connected to 49A, which runs to the turn signal switch thru the connector on the sterring column may not be making connection. ( First thing to check).
Try this and let me know.
buhs914
Jun 29 2009, 09:26 PM
you could check the bulbs.. if they have different filaments it could be a resistance issue.. had a similar problem in mine
silverteener
Jul 2 2009, 10:11 PM
904svo
I did what you said and grounded the black/white wire on the brake light bulb socket and it did flash. I could also hear a clicking sound. So does this mean the emergency flasher switch is bad. I also checked the connections under the dash and they are tight. I found the ground under the dash and it is also tight. The bulbs up front were a little corrided and I had to rip them out with pliers. I put new ones back in. I also checked the rear lights and they are ok. Please let me know.. I miss
thanks
Scott
904svo
Jul 2 2009, 10:25 PM
QUOTE(silverteener @ Jul 2 2009, 08:11 PM)
904svo
thanks
Scott
Ground the black/green wire on the bottom of the steering column plug, this
connector may not be plug in all the way. Which I supect is your problem.
There are two black/green wires one for the right turn signal the other is for the flasher. You may also have a bad turn signal switch.
silverteener
Jul 2 2009, 10:32 PM
this is probably a stupid question but i'm not good at this electrical stuff. How do I ground the black/green wire on the bottom of the steering column plug. Do I just put a wire in the plug and put it on metal? Will the turn signals work if I ground this wire? thanks! Like is sad, I suck at this stuff!
904svo
Jul 3 2009, 08:42 AM
QUOTE(silverteener @ Jul 2 2009, 08:32 PM)
Remove the plug and ground it. connect the two black/green toghter and the right turn singal should work. If it does you have a bad turn-signal switch.
silverteener
Jul 5 2009, 02:38 PM
I'm still trying to get this figured out. I found this yellow and red wire that came out of the plug that connects to the turn signal switch under the dash. Could this be my problem
all the other wires were firmly connected.
thanks
Scott
904svo
Jul 5 2009, 02:59 PM
QUOTE(silverteener @ Jul 5 2009, 12:38 PM)
thanks
Scott
Yellow/red is used for turn on the high beams.
silverteener
Jul 5 2009, 05:31 PM
yeah,
It didn't work. I fixed the wire and decided to put my old turn signal lever/switch back on and they were working again...but, then while out for a drive they stopped... then a few turns later they started working again.
904svo
Jul 5 2009, 06:13 PM
sounds like you need a turn/signal switch.
silverteener
Jul 5 2009, 08:45 PM
so... do you have one
I'll look around and see if I can find one,
thanks for the advise.
