QUOTE(type2man @ Jun 29 2009, 03:31 PM)
A 1.7 is a 66mm crank with 90mm pistons.
A 1.8 is a 66mm crank with 93mm pistions.
A 2.0 is a 71mm crank with 94mm pistons.
All engine cases are the same basically which means you can use any combination of crank and pistons in them with the exception of the 1.7 heads which are only used with 90mm pistons. The 96mm pistons can be used on the 1.8 and 2.0 without machining, but you will need to machine the heads on a 1.7. So basically what the Cap'n said. Find a 71mm crank and 94mm or 96mm pistons and you'll have a 2.0L
1.9 = short stroke hi revs, Fun motor
