I have a '75 1.8 that a friend has given me (nicest thing anyone has ever done for me). I spent the Spring working on the electrical and I am 98% of the way there. The car was a Frankenstein of 3 cars so it has not been on the road in its current setup. I am good with electrical but a rookie with mechanical.
- Below the oil cap is what looks to be the crank case vent
- On the single 4 barrel carb is an air intake fitting
I called Pelican to ask if they carried a hose and they did not have a part specific for the application. A friend of mine warned me a valve should be in place to prevent oil from being sucked into the carburator. Pelican recommended I look to a VW supplier for a filter used in many VW's.
Can anyone give me some direction. Picture attached. Thank you!
