Finally(!) after pushing it aside for months at a time, almost giving up and going to carbs, banging my head against the wall modding the ECU, hoping the wiring was close, it's done, installed and alive!!!! My shop car, a slightly lowered '67 VW Squareback known as "The ProVolks Road Cow" has a new heart. A '73 Porsche 914 2.0L running MS2 w/ EDIS and WBO2.
The engine compartment:
The wiring under the back seat:
I had Vedron from www.spitfireefi.com (a local Bellingham, WA tuner) check my work on all the mods to the V2.2 board and while he was at it loaded some known good VE, spark tables and basic engine parameters from his assortment and wide tuning experience to get me started. They must be really close cause it runs and drives pretty nice as it is. More tuning will obviously be needed to get things perfect, but I'm amazed at how smoothly it idles and revs and runs down the street.
Had some initial starting issues (no pulsing of the injectors or spark at the plugs). After swapping the VR sensor wires (to get that all working) and then swapping the A & B coil wires (because it was firing 180 out), she fired right up and idled smooth. I couldn't be more amazed. . .
Now on to fine tuning. . . Then I need to pull it all apart to powder coat all the tins, plenum and runners and clean-up the wiring to make it all presentable.
Just had to share! WOO HOO!!
