Dr Evil
Jun 30 2009, 08:47 PM
I have a few of the outie tranz drain plugs and want to get some more, but all of the replacement parts are innies. WTF? In the PET many models with p/n 999 064 019 02 and 020 02 are outies so you can use a wrench on them and be happy. No 17mm allen needed. All of the suppliers I found had the same damn allen plugs assigned to the old part number.
If I could find some I would buy a bunch and offer them on all of my rebuilds.
Here is a pic of what I want next to two of the old type that I had to drill out (fun and awesome)
bandjoey
Jun 30 2009, 08:53 PM
I'll take a couple! I've been trying on and off for a year to get mine out..no luck! Bill
Dr Evil
Jun 30 2009, 09:26 PM
So are you selling them?
banger
Jun 30 2009, 10:26 PM
What is the thread size? You can get 20mm dia X 30mm bolts from mcmaster carr, which should work, and are easier to get...
Dr Evil
Jun 30 2009, 10:34 PM
The thread is NPT so it is tapered. The problem I am having with the standards is that they are soft and people keep tightening them down flush which is way to much.
r_towle
Jun 30 2009, 10:36 PM
If that is NPT, go to a plumbing supply house...there must be a real plumbing supply place near you...NOT home depot...
That is a standard gas fitting stopper.
Rich
Dr Evil
Jun 30 2009, 10:44 PM
Well, maybe not NPT, but a tapered fitting. Is there a metric version of NPT? I will check the good hardware store tomorrow
Katmanken
Jul 1 2009, 11:31 AM
Got one of those metric thread checkers?
Got one with my Sears tap and die set and have used it a lot.
JWest
Jul 1 2009, 01:24 PM
It is M24 x 1.5 tapered.
Dr Evil
Jul 1 2009, 03:21 PM
Thanks, James
No luck at the hardware store
914Sixer
Jul 1 2009, 04:48 PM
Here is 3 shots of a NOS drain plug. I have no idea where I got it from. I will ship it to you if you need it to locate others with.
Click to view attachmentClick to view attachmentClick to view attachment
Mikey914
Jul 1 2009, 05:02 PM
PM sent
wilchek
Jul 1 2009, 06:47 PM
Mike,
if you don't find something give these guys a call.
http://www.readingfoundry.com/index.htmlIf not the foundry try these guys
http://www.clarkindustrialsupply.com/
jaxdream
Jul 2 2009, 09:52 AM
Have you tryed welding a suitable bolt to the plug to remove it vs drilling and easy outting ??
The heat should help break it loose some .
Jaxdream
Dr Evil
Jul 2 2009, 11:08 AM
I dont weld, the HOA frowns on it
I MAP gassed the plugs for a while and they did not budge. Drilling them out was the best, safest, quickest bet. I hate doing it, but it works.
rfuerst911sc
Jul 2 2009, 01:26 PM
If finding the correct " outie " plug is impossible what about having " innies " welded with a short section of allen wrench in them? That would turn them into outies correct? Have the section of allen wrench protrude aprox. 3/4 - 1 inch so you can put a socket on it?
Dr Evil
Jul 2 2009, 02:35 PM
Time + resources + $$ = Not on a scale of more than 2
jsayre914
Jul 2 2009, 04:50 PM
QUOTE(JWest @ Jul 1 2009, 03:24 PM)
i just typed what he said into my browser and found this, if that helps
http://efc-capsandplugs.com/productspec.asp?56,136,04A299
Katmanken
Jul 2 2009, 08:05 PM
Yowzers.....
Are we getting close????
http://seawaybolt.com/din.htmlHmmm... that's frickin weird... I can't post an internet linky like I used to....
"you must enter a URL before posting a linky"....
Must be the new XP and Explorer 8.....
Dr Evil
Jul 2 2009, 08:15 PM
Thats it! I wonder how much or how big an order?
ArtechnikA
Jul 2 2009, 09:10 PM
Every 911 ( and 914.6 ) transmission used those, through at least the 915.
Embedded magnet and everything...
I bet every Porsche dismantler in the world has a bucket full of them.
Dr Evil
Jul 2 2009, 10:16 PM
Ya, I know they did. I hadnt thought about dismantlers, though. Maybe I will give them a call. I kinda doubt it, though as these are no pieces in high demand. (yet)
Katmanken
Jul 2 2009, 10:42 PM
Hmmmm.....
Factory Parts book sez....
VerschluBschraube (closing screw) PN 999.064.007.2 fur Alle (including -6)
and VerschluBschrabe mit Magnet PN 999.064.008.2 fur sportomatic
Hope that helps...
Dr Evil
Jul 2 2009, 11:56 PM
Huh, PET has different part numbers. I wonder.
Katmanken
Jul 3 2009, 09:19 AM
I'm using a yellowed 1974 vintage factory parts manual that hasn't been updated. The PET has updated numbers that may be later substitutes.
Looked at the sporto tranny page in the parts manual and it actually has an enlarged picture that shows the plugs as having hex male heads with the same .007 and .008 numbers....
I'd check the dealer or another source for those 999.xxxx part numbers to see if they have them or can get them. At the least you could get a max price.
Katmanken
Jul 3 2009, 09:30 AM
Here's another source for m24-1.5 tapered plugs under piping.....
https://www.fastenersclearinghouse.com/fch/...Cat6=&Cat7=They have them in stock, list a $25 minimum order, and a minimum line item value of $2.00....
It also appears that a M24 1.5 thread is used on oil pan drains... not sure if it is tapered or not....
