QUOTE(swm914 @ Jul 2 2009, 09:01 AM)
Hi, I need to remove the speedometer in my '74 914. The needle still works but both odometers stopped. I want to repair it and put it back in in order to preserve original mileage (54K)
What is the most efficient way to do so?
Must I remove the steering wheel? Is this a simple procedure for a mechanically challenged 914 owner?
Thanks
Steve
Steve,
It's far easier to remove the wheel. And it's easy, and in they way.
Grab the horn ring, push down, and turn it left. You'll reach a stop. Wiggle it a little & it'll come off. You'll be faced with a BIG nut(forget the dimensions - someone help out here). Before you remove the nut (did I say BIG) mark the top position of the spline with a red Sharpie, so you'll know where to re-position the wheel. Remove nut & wheel & you'll have much easier access to the speedo, which also comes out easily.
On the speedo assy, push from the rear slightly, to remove it from the pod. Unscrew the sender , mark the indicator wires, remove the wires & pop it out the front. Easy.
Send the speedo to Palo Alto, or someone else reputable. Have it taken apart cleaned & re-calibrated. Get it back - put it in in reverse order.
Hint....while you're in there, you may want to do the same with the other instuments. They get fogged up over the years.
Nevertheless, they all are easier to access if the wheel is removed - just be certain to mark the wheel position on the spline.
Easy job, even for me!
Pat
