Here's a dumb idea that might get a quick and dirty answer......
Got a running 914? It's aircooled and probably has an intake area temperature close to the corvair.
Run the 914 until it is warmed up.
Using a meat thermometer touch test, get readings on one or more of the intake mounting studs and on the aluminum next to the spacer.
Due to the cooling effect of the incoming air, I betcha the temps aren't too bad in that area.
Other choice might be a thick chunk of fiberglass like a circuit board. Best is epoxy resin The glass is rough on tools though.....
Hmmm.... looks like Ultem (polyetherimide) is in the 300-400 degree range.....
http://www.modernplastics.com/march05/wdtempaluxII.htmlHey, look up a local plastics supply house. I bet Harrisburg has one. Prices may be cheaper....
