914rbust
Jul 5 2009, 11:35 AM
hi folks, I'm new to this computer stuff so bear with me. I've got 1 motor out of my 72 914 -it's definitely 1.8 case Ibuilt it up 20 years ago. The engine #is located near #3.I just acquired 2 type IV motors supposedly out of 79 campers. Engine # on these are located by the oil filler . Haynes says this location indicates 2 liter but my measurements indicate 1.6--66mmx88mm.WTF? Iknow haynes has some terrible flaws lke put #3rod on upsidedown (thats why the guy gave up after 3 rebuilds and sold me the car for$200) but is this engine possible?Haven"t torn the third motor apart yet.A forum at another site says "cb" is a 1.6 this engine #does start with "CB". Any thoughts on this?Why would anyone put a 1.6 in a 79 camper??By the way I lost my old books and am waiting for new ones to be delivered. NO NOT HAYNES! Bently,Muir,any others you guy like.
McMark
Jul 5 2009, 12:02 PM
All you need to know is
here.
EDIT: apparently Tuna had a hardware failure. Try
this link temporarily.
914rbust
Jul 5 2009, 01:02 PM
QUOTE(McMark @ Jul 5 2009, 10:02 AM)
here.
thanks for the link but it didn't answer the ?
Jake Raby
Jul 5 2009, 01:09 PM
CB= 1700cc Bus spec engine used in 1972
If they are 79 Bus engine's they'll be GE coded and will have hydro lifters.
Todd Enlund
Jul 5 2009, 01:14 PM
QUOTE(914rbust @ Jul 5 2009, 09:35 AM)
CB is a 1.7 bus engine, but not from a '79. 66x90. Measure again?
914rbust
Jul 5 2009, 01:33 PM
Thanks guys !!! My measurements could be off (using tape measure,I know just all Igot at the moment)The other motors are -"EA" &"GD" any thoughts?"GD" is still in 1979 camper. P.S. can I use the 96mm jugs from 1.7 crank with a2.0 crank??
orange914
Jul 5 2009, 03:09 PM
QUOTE(914rbust @ Jul 5 2009, 11:33 AM)
jugs yes, pistons, no, the pin height is different. do you have opened up 1.7 heads or 1.8 or 2.0?
914rbust
Jul 5 2009, 04:43 PM
Apparently, I now have a set of 1700 's untouched;1800's opened up ,ported &huge valves; &hopefully a set of 2.0's . I say hopefully because it is still in the camper, so what it is ,is still up for grabs since supposedly the 17was 2.0
914rbust
Jul 7 2009, 02:29 PM
Still nobody recognizes the "EA" &"GD" engine codes? The "CB" info seems to be correct , but still trying to find out what the others are . Both of the "new to me"engines show signs that somebody"been there before. The motor "GD" has what appears to be a temp sensor screwed into one of the shroud screw holes next to the intake (screws into head). Looks like somebody ripped a hole in the shroud to make room for it. I'm going out to tear the sucker apart to see what's inside. other than mud, tranny fluid (yeah, I know, they dumped it in to try unseize it) andother crap since they left the plugs out.
904svo
Jul 7 2009, 04:18 PM
EA=1700 type 4 engine 1972-1974
GD=2000 type 2 engine 1976-1979
Check out this link.
http://www.type2.com/bartnik/enginecodes.htm
Katmanken
Jul 7 2009, 05:17 PM
Be aware that bus 2.0's are a lot different than 914 2.0's.
Bus runs lower compression pistons (and lower power)
Bus runs bus 2.0 heads which are a lot less effcient than the 914 2.0 heads (aka apples and oranges different)
Bus heads are usually toast due to overheating from pushing a bus that is the size of a small living room through the air....
The bus cases will need blockage plates to seal the angled oil filler pipe- 914's fill from an oil fill port on top of the engine.
Some of the bus heads run square exhaust ports- not the 914 ovals and the square port exhausts for a 914 don't exist.
Hope this helps.
Ken
914rbust
Jul 7 2009, 07:50 PM
Thanks folks! This internet stuff is pretty cool. Just got the "GD" engine down to the block and your info matches my measurements. As far as the P&C's go... I don't care about them, they're just for spares . In case I have to do something in a hurry and got no cash. All the heads appear the same. I'd like a set of 914 2.0 heads but... My old set is pretty radical for 20 years ago. basically as much as could be done w/o welding. Maybe I should give some background.bought my first 914 in 85. A 72 that had all the usual rust issues. I spent all my $ on the motor,put it in the car,revved it up ,sidestepped the clutch and sent the floor into the pavement literally breaking the car in half. Hell of a ride.It pulled the throttle wide open and snapped the clutch cable. After that I had a 73 given to me as a junker. Started fixing the hellacious rust . Got new longs, firewall bottoms then got hassled by the man. No "junk cars" they were shooting some movie and they had more clout than me and I came home from a long weekend and they had taken it. Nobody knew where it went and I looked everywhere. Number 3 went down the road after a divorce.Number 4 I bought as a project with my son, his car, that came no motor or tranny and I wasn't able to find one before bankruptcy and forclosure sent that one away.So I've owned 4 but probably driven less than100 miles.Now my son has a 66 based Manx. I bought this camper in excellent shape bodywise for a song and was hoping to get a couple of 2 liter cranks to play with. Alas I only got 1. Anyway, I did get a flywheel that will let me put the 914 motor in the Manx. That should liven it up some. Now I'm looking for a 914 in Central New York area,cheap so I can talk to Jake about a motor for it. Thanks for letting go on and on . I'll shut up for now and promise never to go this long again.
