Full Version: Quality Front-end alignment in PNW
aircooledtechguy
I've got a front end that needs everything checked and made right. I've got to much camber on the passenger side and the inside edge of that tire is going bald (all others are fine). I've had it on my lift with no bent stuff noted, it just appears to need adjustment. Who do you use in the Puget Sound region?? I'm not about to drop my 914 off at Les Schwab for some teenager to thrash on and I don't own any alignment tools or I'd do it myself. . .
slow914
When my car is done it will be going to Cantrell, they are located in Kirkland bit of a drive but id trust em just about anything, cool guys, nice shop. They've done a lot of work on our shops cars good stuff...
http://www.cantrellmotorsport.com/
greenie
I have used:
Omni Brake & Alignment
124th Ave NE. Kirkland, WA 98034. ph 425-823-1511
They know these cars, even had the shims in stock.
I was very pleased with the work they did .
sixnotfour
Cantrells is on th west side of the 405 freeway from Omni , 2 good choices close to each other.
