After sitting in the garage for over 3 years my then girlfriend told me to move my 73 1.7 or fix it in order to make room for her boxes. Well, the boxes never made it in the garage but were usefull when I asked her to move it! Now I have a problem with my brakes and need your help.
I have rebuilt the front calipers since they were frozen with rust, replaced the rotors which were out of spec, replaced the top nipples with speed bleeders and purchased a 19mm MC. All went well until it was time to bleed. Here's were I need your help.
My two front calipers along with the left rear bleed just fine but can not get the right rear which was were I started to bleed. I can hear the pressure in the lines and have confirmed the caliper is getting fluid by disconnecting the line to the caliper. Let me meantion that the caliper does not leak at all. Do I need to rebuild the rear calipers or can it be that the proportioning valve is not building enought pressure on that side? What are your thoughts?
