Full Version: 1.7 head ID
r_towle
What are the valid part numbers for a 1.7 head....
OR
What is the register size for the cylinder in the head?
Rich
HAM Inc
021 101 371 Q is the most desired 1.7 head. the "J" is okay too, but doesn't have a bit of the extra beef that the Q head has in the ex port area.
The O.E. registers on all 1.7 heads are ~100mm
r_towle
QUOTE(HAM Inc @ Jul 11 2009, 12:24 PM) *
A guy wants a 1.7 head that I have.
I need to make sure its not a 1.8 head.
~100mm for the 1.7 head register.
What is the 1.8 register?
Rich
Dave_Darling
I believe the 1.8 and 2.0 registers are 105mm.
--DD
r_towle
that is exactly what I need.
Just so long as they are far enough apart so I know..
Rich
HAM Inc
Those are the O.E. specs. Folks get thrown off once in a while when they encounter a 1.7 head that has been opened to 105mm. An easy way to confirm that you have a 1.7 head is to look down the intake port from the manifold flange. 1.7 heads have no fairing above the valve guide. 1.8 and 2.0 914 heads do. Ofcourse the 2.0 914 heads are easy to spot because they have 3 intake manifold studs.
