sean_v8_914
Jul 13 2009, 01:03 PM
Wow. This thing was really rusty. I wish I had a pic of the fiberglass that was over this mess hiding it and helping the rust to gestate. Check out the bondo chunks. There was bailing wire holding the heat shield in place
notice how "clean and solid teh one corner looks. also teh trunk latch support boss. although they look sano, they are paper thin and rotted from behind where you cant see them...yet
sean_v8_914
Jul 13 2009, 01:04 PM
fdh
sean_v8_914
Jul 13 2009, 01:05 PM
xcg
sean_v8_914
Jul 13 2009, 01:06 PM
fdyrd
sean_v8_914
Jul 13 2009, 01:07 PM
fdyh
sean_v8_914
Jul 13 2009, 01:10 PM
Although the rear trunk section was obliterated, the muffler heat shield was perfect. Drilled out the spot welds on the transaxle cross brace reinforcement. The underside was rusty so I made a new one. I sand blasted the corners and the remaining rust that I could not grind. then I treated the raw metal with phosphoric acid AKA Ospho/metal ready/rust-mort/PPG DX-XXX...
the late model bumper shock mount brackets are stout! They reside in the corners under the trunk floor.
This trunk pc was galvanized. Be careful welding this toxic brew!!! I ground it off of the major weld areas and re-coat with a zinc rich weld thru primer. I use Wurth. it is critical to the longevity of a repair like this that no metal be left un-treated
sean_v8_914
Jul 13 2009, 01:11 PM
heat shield
sean_v8_914
Jul 13 2009, 01:12 PM
fdh
sean_v8_914
Jul 13 2009, 01:14 PM
xcg
URY914
Jul 13 2009, 01:15 PM
I'm in the middle of the same kind of repair.
sean_v8_914
this was the only solid metal. note the rust hidden under teh rear trans cross support
sean_v8_914
Jul 13 2009, 01:18 PM
prelim fittment. dont weld galvanized metal w/o a PROPER respirator!!!!!!!! it emits toxic evil mess you up fumes
sean_v8_914
Jul 13 2009, 01:21 PM
customer was not concerned w originality in this area
sean_v8_914
Jul 13 2009, 01:23 PM
Seam sealing the bottom is very important to the longevity of this repair. I also use Wurth or 3m weld thru primer anywhere I’m welding that I know I cant get to after the weld. Although I make allot of my metal for fun, RD is the more economical solution for pre-made quality steel. They come with an unknown soft primer that I remove. I am scared of peeling so I do everything I can to control the process from bare metal to finished paint.
clean, strip, clean, sand, clean, etch, clean, etching primer, epoxy primer, sand, then paint
sean_v8_914
Jul 13 2009, 01:25 PM
The trunk latch support boss was toast also. It has no drains on its bottom. I scrubbed t4eh hell out of that seam sealer in the upper trunk since I knew I would be painting the whole thing later. after sanding I used etching primer on all bare metal and an epoxy primer to seal it all off
while I was in there I decided to weld up some extra holes from one of those plastic reflector things. This required me to paint the rear apron and outer tail light panel
sean_v8_914
Jul 13 2009, 01:27 PM
I was happy that most of the rusty got cut out with the rear section. I have done one where the rust was also forward of the trans brace. Water accumulates there but not as bad.
the moral of the story is SEAL YOUR TAIL LIGHTS
sean_v8_914
Jul 13 2009, 01:30 PM
gfh
sean_v8_914
Jul 13 2009, 01:35 PM
the engine and hell hole were the same before i started on this baby. now its a 1911cc 8.6 to 1. replaced teh hell hole, inner wheel house and teh left mini hell hole too
I wish this was my car. its so complete now. its a paint job away from 914 greatness
sean_v8_914
Jul 13 2009, 01:37 PM
vhn
sean_v8_914
v ngf
sean_v8_914
Jul 13 2009, 01:38 PM
vhgfhn
sean_v8_914
Jul 13 2009, 01:40 PM
I love my job!
sean_v8_914
Jul 13 2009, 01:43 PM
URY914: why would you add weight to your car? ....or do you speak of a different car? that light weight thing is bad ass!!! we just got our AX car down below 1700#. scales dont lie
sean_v8_914
Jul 13 2009, 01:44 PM
gvj
sean_v8_914
Jul 13 2009, 01:46 PM
HELL on earth
sean_v8_914
Jul 13 2009, 01:47 PM
dsgfdb
sean_v8_914
Jul 13 2009, 01:48 PM
mini hell
sean_v8_914
Jul 13 2009, 01:49 PM
xgch
sean_v8_914
Jul 13 2009, 01:59 PM
...back to the next rusty beast
...with a glimps of its future in teh background
914Owner
Jul 13 2009, 03:12 PM
Looks purdy now.
oldschool
Jul 14 2009, 12:16 AM
QUOTE(sean_v8_914 @ Jul 13 2009, 12:38 PM)
vhgfhn
very nice I'm on my way to fixing my ride also
sean_v8_914
Jul 14 2009, 01:01 AM
ouch. do you need any donor metal? show us the rest of teh damage. do I see a ripple half way up the seal flange?
oldschool
Jul 14 2009, 02:39 AM
QUOTE(sean_v8_914 @ Jul 14 2009, 12:01 AM)
FourBlades
Jul 14 2009, 06:15 AM
That is some beautiful work Sean!
Thanks for posting all the pictures. I needed a rustoration fix.
What do you say people, welder of the year nominee???
John
sean_v8_914
Jul 14 2009, 12:28 PM
John, you got me beat by a long shot. you got my vote. your project was epic, man. Is she runnin yet?
oldschool: are you butting that in?
sean_v8_914
Jul 15 2009, 03:34 AM
for those who asked about material costs...I di not use the full gallon of paint, primer, rust mort but it would be stupid to pay the quart price.
Epoxy primer $120
Rust mort $62
Urethane single stage $120
Seam sealer $30
Etching primer $15
Weld thru primer $13
Welding gas $10
Replacement sheet metal $175
sean_v8_914
Jul 15 2009, 03:41 AM
forgot welding wire, grinding wheels, sand paper, blasting sand, sawsall blades, spot weld drilling bit, dremel cutting wheels, sanding discs, degreaser, wax and grease remover, paint thinner, laqueur thinner, body filler...
URY914
Jul 15 2009, 07:09 AM
QUOTE(sean_v8_914 @ Jul 13 2009, 12:43 PM)
I'm fixing the trunk in my street car. No trunk in the race car.
Tom
Jul 15 2009, 11:48 AM
Sean,
It's obivious that you love your job. I love your work! Looks soo nice! Wish I still lived in San Diego. I would be happy for you to do some work for me on mine. Nothing that bad, just small dings and paint work.
Tom
sean_v8_914
Jul 19 2009, 01:26 PM
old school bump...any progress?
