2 Good used porsche '87-'91 944 turbo/ 951 Axles. Kept in clear wrap to keep the cv's clean. Removed from an '89 944 turbo parts car that was hit in the front. I originally bought them for an axle swap, but I ended up doing a carrera axle swap b/c I had more parts on hand to do them.
specs:
100mm in diameter, and about 21 inches in overall length, with the cv's about flush to the axle ends. They use (6) 8mm bolts, not sure what else you would need for the swap... I think the spline count is 25 or 26.
Asking $100 shipped to the lower 48 states.
