Thanks TC, No it's not a recent rebuild, I did that the last resto('03) but what I;ve been trying to avoid is cranking the engine 'dry'. The idea of all the bearings, pistons, cam, crank lifters, rubbing and grinding without lube...wait maybe all that's needed is to talk low and blow in her tail...pipe...
uh, sorry, just went to Jamaica for a minute, but I'm back now. Think I'll call around and find a new pump primer shaft. I'll also take Your suggestion about spraying sone lube in the cylinders, I'd forgotten about that. BTW, that's kinda strange (at least to me, I'd never heard of it before) about Your oiling system not being the same on both sides, what year is it? I know the 4.3 will prime on both banks because I did it last time I rebuilt it.
And Ken, I really need to take some shots of My single garage/shop with all my work supplies, tools and equipment, as well as the porsche stripped with parts everywhere, and tools and equip. for it, work bench at one end, shelving along both walls, Then add My 275lb frame squeezing through the remaining 8-14 inches trying to complete a extensive refurb/resto/upgrade. Maybe we should start a new thread, 'Show Us Your Sh** Hole' .
