JRust
Jul 15 2009, 10:33 PM
McMark
Jul 16 2009, 12:42 AM
Which will be better for this? Fiberglass or JB Weld?
Sucks. There's no patching that one.
JRust
Jul 16 2009, 01:07 AM
What is the proper way to fix it? How much do I need to cut out?
lotus_65
Jul 16 2009, 05:25 AM
seems to be a lot of this right now,
there was at least one other thread when mine was active a couple weeks ago.
http://www.914world.com/bbs2/index.php?sho...c=96575&hl=it's a pita, and if you have any hp at all you need to reenforce.
it looked to me like this is the last spot for the acid dosed rainwater to have collected all those years.
thefleur
Joe Ricard
Jul 16 2009, 06:00 AM
Unfortunately you will need to remove the whole damn thing and replace it with a new one. Drill out the spot welds, and fit up a new one. get some measurements from a known good car.
If you are putting in a big motor and sticky tires you can just go ahead a put the plate on now.
Joe Bob
Jul 16 2009, 09:10 AM
Joo need to reepace everyting, Loosey....joo lookey it doan brake when joo be dryben it....
dr914@autoatlanta.com
Jul 16 2009, 10:43 AM
QUOTE(JRust @ Jul 15 2009, 09:33 PM)
Tremendously worthwhile project. We make that part of course and have many in stock
JRust
Jul 16 2009, 04:05 PM
QUOTE(Joe Ricard @ Jul 16 2009, 05:00 AM)
What do you mean by plate? Is that part of a reinforcement kit? Who makes the kit? Or anyone have a link to a thread that replace this whole deal? Thanks
JazonJJordan
Jul 16 2009, 04:12 PM
markb
Jul 16 2009, 04:33 PM
And you tracked that at WCR? Musta been the sticky tires that did it.
Wow, lucky it held to get you home.
We also have the replacement piece in stock.
JRust
Jul 16 2009, 04:54 PM
QUOTE(markb @ Jul 16 2009, 03:33 PM)
It's possible the starting crack happened there. I really don't know. I also did an AutoX in Bremerton WA. It's a good 4 1/2 hour drive for me. I did it with no problem & had none on the drive home. I can't think of a time where it happened. I can remember driving one afternoon & takin a semi sharp left turn. Felt a little squirly but just thought my tire was low. Checked when I got home but tire seemed fine. I think the crack was there & just getting worse each time I drove it. Having a v8 probably didn't help it much
Hey Mark where is it listed on your site? I couldn't find it
Katmanken
Jul 16 2009, 05:51 PM
That's a combo rust/fatigue crack and has been happening for awhile...
Notice that a lot of the crack is rusty which means it happened a while ago which is consistant with mild steel. High temeper materials would snap with a clean unrusted break surface, and with the the mild steel, the crack would march along the part allowing old breakage areas to rust, and the new break to look shiney.
Which is exactly what happened here.
I'm just glad that it happened with no damage to you, and with minimal parts damage (broken ear).
JRust
Jul 16 2009, 08:57 PM
Believe me I am very thankful it did not break loose completely while driving. Seeing where it was at I am sure it would have come completely off. If I had not caught it
r_towle
Jul 16 2009, 10:55 PM
The plate would be put on after you install the new suspension ear.
Chris Foley makes the overlay plate.
You may also want to add a brace to the firewall like Brant/JP...
Rich
Justinp71
Jul 17 2009, 12:12 PM
QUOTE(r_towle @ Jul 16 2009, 09:55 PM)
Rich
I just did this aswell when I had my engine out... Chris (at CFR) sells a very nice adjustable heimrod brace that goes from the ear to the firewall.
Sorry to hear about this... thats a very nice car you have.
http://www.tangerineracing.com/chassis.htm
PeeGreen 914
Jul 17 2009, 12:30 PM
Jamie, Chris actually has a setup that is very nice. That would mean doing both sides but I would think that may wise to do anyway. Not wanting to take any business from GPR but Chris's system really does look like the way to go here.
PeeGreen 914
Jul 17 2009, 12:37 PM
Never mind... I looked and I was thinking of his raised rear pickup points... The hiem joint dos look like a good idea though when you do fix your ear.
McMark
Jul 17 2009, 12:42 PM
Pics from a replacement. It's a quite a PITA on the underside.
JRust
Jul 17 2009, 04:58 PM
I got it Mark
. How about I bring you a front clip for your pheonix. Along with me & my car. We spend the weekend fixing mine. I leave the clip
. Piece of cake
McMark
Jul 17 2009, 07:51 PM
Hmmmm, I'll consider the front clip
extremely partial payment.
It could be done in a day if the motor is already out.
JRust
Jul 17 2009, 08:15 PM
QUOTE(McMark @ Jul 17 2009, 06:51 PM)
Yeah there was some sarcasm there. I really don't want to load all that up on my trailer & drive 9 hours one way. Make for a very long weekend to say the least. Not looking forward to the repair but I do have a buddy close by that welds. I'll start getting things prepped & go from there. I really have no plans to head south to CA anytime soon. Be nice to have ready for the 914Shootout next month but will be tough. I have to many things I want to do to my drivetrain. If I'm pulling it I may as well start my list
. We shall see though
McMark
Jul 17 2009, 09:19 PM
I got your sarcasm. Mine was even dryer than yours.
I just thought you were in love with I-5.
brant
Jul 17 2009, 09:44 PM
I did this twice (on the same car)
it was not rusty either time....
much less rusty than yours
I'd recommend a brace. Obviously you are pushing the limits of the stock frame.
I braced my first racer (the one that tore out twice) about 12 years ago and never had a problem since. I braced my 2nd racer as I was building it and never had a problem at all........
JRust
Jul 17 2009, 10:03 PM
I ordered the brace & if not sent out today hopefully on monday. I'm pulling the drivetrain tommorow. Anyone have a step by step & pics for what to cut out?
sww914
Jul 18 2009, 12:37 PM
I don't drill spot welds often anymore. I grind them out with a 3M #1991 disc in a die grinder. Much much faster and after you peel the junk metal off the good metal underneath is seconds away from ready to weld to instead of left with a bunch of holes or little round pads left behind.
http://www.shopping.com/xPO-3M-1991-3M-Gre...g-Wheels-5-Pack
strawman
Jul 18 2009, 02:58 PM
with SW914. I only use the spot weld drills if I need to reuse a part that I'm cutting off...
Geoff
JazonJJordan
Jul 18 2009, 10:24 PM
QUOTE(kwales @ Jul 16 2009, 07:51 PM)
Well said-
JRust
Aug 10 2009, 11:46 PM
Okay so I'd still like to see a how to thread. I am fairly confident I can do it with a friend welding it for me. I am a little worried about getting it in the proper position. I was thinking maybe drilling a few guide hole on around the one I am taking off
. What did you do? Thanks
Aug 10 2009, 11:52 PM
QUOTE(JRust @ Aug 10 2009, 09:46 PM)
Brad posted a pictorial a few years back. If you're lucky, he didn't delete the pictures
Might have been on Sean's old white car?
Andy
JRust
Aug 11 2009, 12:20 AM
QUOTE(SirAndy @ Aug 10 2009, 10:52 PM)
Andy
Found it in the tech articles but no pics
strawman
Aug 11 2009, 08:48 PM
See posts 29 & 30 of
http://www.914world.com/bbs2/index.php?act...f=2&t=83031 for the jig I built prior to replacing the inner passenger console on my teener. You'll definitely want to tie the jig into at least two planes to be sure you can place the new console in the correct place.
I obtained my replacement console from Auto Atlanta. Since I constructed my own upper/rear long replacement pieces, I had to massage the replacement console to correctly align the jig.
Best of luck!
Geoff
r_towle
Aug 11 2009, 09:16 PM
QUOTE(JRust @ Aug 11 2009, 02:20 AM)
Andy
Think in 3D
All you care about is the final location of the hole...the hole that holds the inner suspension bolt.
Now...measure forward to the firewall.
That gets you in position front to back.
Measure from one hole to the other...
That gets you at the right width.
Lastly you need to measure down from the longitudinal to the hole.
This gives you the three measurements that you need.
Rich
ChrisFoley
Aug 12 2009, 07:54 AM
In my experience, if the long is in good shape the console only fits well in one place, therefore pretty hard to get it wrong.
Since your console is broken already use the left side for the measurements that Rich suggested.
Shade Tree
Aug 12 2009, 02:18 PM
Hey Jamie, I do have that part but it sounds like it's too late. Also, as far as getting it centered properly. Old man Joe, who has a v8 914 about 3 blocks from my office, had a machinist make a jig to get the ear in the right place. He'd let you borrow it. He used it once while building his car and now it sits waiting for somebody else to have a rusty suspension ear. Anyway, you have my number. I can introduce you to Joe and you'll have the stuff you need to get it right without a struggle.
Rich.
roadster fan
Aug 12 2009, 09:07 PM
Hey Jamie,
When the new part arrives it will be pretty obvious what you have to remove to make it work. Just measure the one that is in there in a couple of spots and record them. The new one will really only fit right where your damaged console is but just double check with the measurements.
You can drill out the spot welds if you want (about 50 on the engine bay side alone, more on the bottom) or just cut and grind the old one out. I would mark the old one's position with a sharpie and go to town.
You are lucky since you dont have to save the cooling tin shelf that goes around the ear. Is yours still there or already removed? That is the piece that gets in the way. Oh and the area around the motor mount on the long also, but that is easier than the engine tin shelf. Hope this helps, maybe you can do the tutorial and they will make it a classic!
Jim
JRust
Aug 13 2009, 12:46 AM
QUOTE(Shade Tree @ Aug 12 2009, 01:18 PM)
Rich.
Hey that sounds great Rich. I'll give you a call. I need to meet a couple of the guys you were telling me about down there. Talk to you soon
JRust
Aug 13 2009, 11:01 PM
I got my new suspension ear today. Thanks GPR (HWGunner) for getting it out so quick. I only ordered it monday. You guys are quick
I am going to pull my drivetrain satuday. The get to grinding off the many spot welds. May do a mixture of drill/grind depending on location. I hope to get it out & prepped for the new one. I will see if I can get the jig Rich mentioned too. Then I just need to bribe on of my buddies to come by &
for me
JRust
Sep 15 2009, 02:43 PM
Okay so an update is in order. Have my drivetrain all out & am ready to grind the welds. I've got EyeTrip (Cory) coming down saturday to weld the new one in place for me. Swapping him a transmission for welding for me. Love trade
I am hoping to get it all ready & do the falling leaf tour next month. Had more stuff I wanted to do with the motor out but I'll settle for shifting my drivetrain back the 1" 1/2. That will help me get my firewall back a little more. The remote Electric pump will wait till winter
. After the PNW Tranny clinic I just want to drive my 914 again. Also excited to see how much difference the "h" gear will make on the hwy
JRust
Sep 17 2009, 11:05 PM
Okay so eI went to start grinding welds. Looks like there was some metal added below. There is a piece that overlaps where the replacement goes underneath? SO I am not sure how much to take off. Not sure if my picture will show it that well
914_teener
Sep 17 2009, 11:25 PM
This is a great post. Keep the pics coming. I was looking at this part yesterday.
JRust
Sep 17 2009, 11:40 PM
I'll put a wire brush attatchment on my grinder tommorwo to see how large the piece is. Just hoping someone would chime in with the info
FourBlades
Sep 18 2009, 06:32 AM
The inner and outer suspension points are connected after they are put on using
a plate of 14 guage overlapping and bent over both. Around the middle pages
of my 73 restoration I have pictures of how I put my console on and put on
the overlapping reinforcement. I just made one out of scrap metal and welded
and bent it progressively over the parts.
http://www.914world.com/bbs2/index.php?sho...tion&st=100John
Joe Bob
Sep 18 2009, 07:55 AM
"Project 6" did a recent complete suspension console replacement. He did some pics and has some input.
JRust
Sep 18 2009, 11:14 AM
QUOTE(FourBlades @ Sep 18 2009, 05:32 AM)
That is perfect thanks for the link & explanation. I figured it was just a plate but didn't want to take the chance of screwing up another part. It would have been obvious had I got all the undercoating off before asking. Was just limited in my time in the garage last night. I'll get it all cleaned up tonight. Welding in the new ear tommorow with some help from EyeTrip from the world. I also have CFR's reinforcement piece to weld on both ears. I didn't get the brace but do plan to do that eventually too. I'll post some more pics as I go. Going to document each piece & make a consise tech article on it. That way it will be a brief & not involve someone going thru a whole thread. Just to find the info they want on replacement. How well it turns out remains to be seen
JazonJJordan
Sep 18 2009, 02:31 PM
QUOTE(dr914@autoatlanta.com @ Jul 16 2009, 12:43 PM)
JRust
Mar 23 2011, 09:57 PM
Okay so fast forward a year & a half. I am now getting to my suspension ear again. Spent some time grinding off the reinforcement plate under the suspension ear off. What a PITA! I stopped after getting a little overagressive & going through my frame.
. Not alot but I couldn't see for
with all the sparks & I was frustrated it was going so slow. So I bailed last night pissed off for being an idiot (not a first
). I will be working on it more this weekend. A friend was going to come down tommorow night to weld the new one in. I had to put it off until next week to be sure I would be ready.
Some of the suspension ear welds I can't get to with the grinder either? Guess maybe a dremel with the right tip. I will drill out the rest of the pinch welds up top this weekend. Then I'll tackle the underside with the top done. Should be a little easier doing the bottom with the top off & out of the way. Grinding effectively is an art I need to get much better at though
(I thought my head might last night)
Eric_Shea
Mar 23 2011, 10:54 PM
You should have driven 9 hours to McMarks back in 2009. I woulda been done a couple years ago!
sean_v8_914
Mar 24 2011, 07:52 AM
sarch my screen name. I have posted a few replacements (I hope it was not on 914club)
these things rust inside, get weak then break. brace it up only if you track it with fat sticky tires. HP has nothing to do with it. grip is what determines this.
add spot welds to the inside seams
sean_v8_914
Mar 24 2011, 07:53 AM
I attach the replacement with screws, then do a mock-assembly to check toe adjustment
JRust
Mar 24 2011, 10:01 AM
QUOTE(sean_v8_914 @ Mar 24 2011, 06:53 AM)
I was planning on doing that to make sure everything is in the right spot. I sure as hell don't want to do this twice
. It's about time I get to it. I've let to many projects leap frog this one. Pretty pitiful as none of them are working yet. I could have fixed this a year ago & been driving this 914 again
. I guess better late than never.
