I recently converted my car to Subaru, which a ton of you already know. I am looking to clean up that area in the original relay location. I have already eliminated the relay board and bought the plug so i can plug into the stock plug coming back there, but i want to eliminate the 5 relays i have bolted to the firewall and the painless wiring fuse block/ relay board. I would like to have a unit all inclusive, ONE maybe waterproof or water resistant nice looking MODERN board.
Any suggestions guys?? Without spending a LOAD of $
thanks
relays are for (1) coil, injectors, idle control (2) fuel pump and oxygen sensor, (3) intercooler h20 pump, (4) LINK ECU, (5) 2 radiator fans up front.
Fuses are for all the above, plus some extra. (boost control valve, etc.)
