ellisor3
Jul 17 2009, 12:11 PM
I have had this ongoing problem with the shifting. Everytime I try to shift into Rev, 1st, 4th or 5th, the shifter slides to neutral. It will not stay in those positions. I do not think I have a clutch issue, and I can not find a linkage issue. It appears that all the bushings are in place, and nothing is broken. Please take a look and provide any suggestions.
tat2dphreak
Jul 17 2009, 12:18 PM
2nd to last pic.. I don't see a firewall bushing
1st pic I can't tell what I'm looking at...
the second pic looks... odd... I can't put my finger on it, but it's been a long time since I looked at the bottom of mine. you do have the piece where that front rod attaches to the shifter, right? that's the only part I don't see a pic of....
it could be your linkage is just out of adjustment.. or you might have a tranny problem
rick 918-S
Jul 17 2009, 12:23 PM
Your firewall bushing looks way big for your shift rod. And is the cone screw loose on the u-joint? I would back it out and chedk ti see it is seated in the dimple on the rod. It may be tight snug but not seated so the u-joint can move on the rod. Look at the way the cone screw looks on the dog foot, then look at the cone screw on the u-joint.
shoguneagle
Jul 17 2009, 12:38 PM
I do not like the looks of any of the bushings! Everything appears to be well worn.
I think Rick may be onto something regarding the cone screw. It does look like it may be loose; or, sheared. How are splines in the shift lever? What you have is something not holding in the external positions, both laterally and lengthwise.
Another possibility is that the shift linkage at the gear shift may be adjusted to short and it vibrates back to the normal position of 2nd/3rd.
I will be under my car later this morning and will see what "could be going on" with your shifting.
jsayre914
Jul 17 2009, 01:06 PM
i think your missing one of these
tat2dphreak
Jul 17 2009, 01:09 PM
QUOTE(jsayre914 @ Jul 17 2009, 02:06 PM)
lol, aren't we all...
ellisor3
Jul 17 2009, 01:19 PM
The first photo is the bottom of the shifter, there are supposed to be two plastic plates, and upper and a lower. I am not sure if these plates are supposed to move apart as in the photo. I will check the other suggestions and get back to you.
Thanks
VaccaRabite
Jul 17 2009, 01:44 PM
Replace your bushings and cone screws. You issues will likely go away. Pelican sells a kit to do this.
Your firewall bushing is either not there or so worn it may as well be not there.
Zach
PeeGreen 914
Jul 17 2009, 01:49 PM
QUOTE(tat2dphreak @ Jul 17 2009, 12:09 PM)
no.
ellisor3
Everything is tight from front to back with no slipping. Take a look at this picture and tell me what it says.
rhodyguy
Jul 17 2009, 01:57 PM
in the shot with the shifter ball, those 2 bushings should be on both sides of the ball (one on top and on on the bottom of the ball). looks as though they are both on one side. incorrectly installed or something has worn and collapsed. either way the shifter assembly needs to be rebushed. there should be a spring in there too. firewall bushing is worn, badly from looking at the picture. presume all bushings should be replaced rather than going thru the system repeatedly.
rhodyguy
Jul 17 2009, 02:00 PM
that allen screw was loose? regardless, your bushings are in need of refurbishing.
ellisor3
Jul 17 2009, 02:07 PM
The allen wrench goes straight through the hole, isn't there supposed to be a screw in there to keep it from spinning on the head???
Jul 17 2009, 02:08 PM
QUOTE(ellisor3 @ Jul 17 2009, 11:49 AM)
Looks like you're missing the allen setscrew on the back of the shift rod ...
Andy
rhodyguy
Jul 17 2009, 02:20 PM
what allen? i just checked a trans laying on the foor. it's a triple rolled pin. hollow. unless the piece is not solidly fixed to the shaft keep looking.
URY914
Jul 17 2009, 02:25 PM
Correct, that is a shear pin not an allen bolt.
ellisor3
Jul 17 2009, 02:33 PM
QUOTE(rhodyguy @ Jul 17 2009, 04:20 PM)
So there is supposed to be a hole and no screw?
Is there supposed to be in play between the horizontal shift rod head and the vertical transmission shaft?
Mine appears to slip a little around that shaft (I hate when that happens)
rhodyguy
Jul 17 2009, 02:39 PM
the pin may have partially sheared allowing for some movement. the ball lever (the part on the shaft) should be solidly fixed on the shaft. the lever should neither rotate or move up and down on the shaft.
Dr Evil
Jul 17 2009, 02:46 PM
Since the allen wrench goes through the roll pin I would not think it is sheared, but check to see if there is any play.
Your cup bushing in the last pic is cracked and looks like poo. I agree that you need to change your bushings and address the issues mentioned with the incorrect shifter bushing placement in your stick shift.
ellisor3
Jul 17 2009, 02:53 PM
QUOTE(rhodyguy @ Jul 17 2009, 04:39 PM)
I think you are dead-on, there is movement both vertical and horizontal around the shaft. Not much but enough to make a difference
How do you seperate the head from the shaft?
Do you simply drive the pin out one side or the other?
Jul 17 2009, 03:00 PM
Well, what do you know, mine has a allen screw in there ...
Andy
Jul 17 2009, 03:05 PM
Like so ...
URY914
Jul 17 2009, 03:06 PM
Be careful driving that pin out. I would start with drilling out as little as possible and than use the next size up. DO NOT use a drill bit size that will screw up the hole that the pin goes thru. After you drill out some material, try to press the pin out using a c-clamp and a smaller pin.
Dr Evil
Jul 17 2009, 03:07 PM
Post #10 left side shows the screw you pictured, Andy.
Jul 17 2009, 03:10 PM
QUOTE(Dr Evil @ Jul 17 2009, 01:07 PM)
Really? My eyes must be getting old ... To me, it looks like there's just a hole, but no screw ...
rhodyguy
Jul 17 2009, 03:11 PM
andy, look again. you pictured the rear shift coupler in the shot off of your car. the dr has a trick or 2 for removing the pin i'm sure.
andy, the whole bracket and shaft system appears dif in your car. what sort of trans are you running?
ellisor3
Jul 17 2009, 03:15 PM
Thanks a lot guys for the help
, got the bushings on order, does anyone know the part number for the Shear Pin?? I can not find it in the manual.
Dr Evil
Jul 17 2009, 03:16 PM
I dont think you can order the pin, but I have a few used ones if you need.
rhodyguy
Jul 17 2009, 03:22 PM
the 2 ball lever bushings aren't included with the bushing kit if that is the way you ordered. seperate items. if you've never taken apart a shifter assem before, you're in for a treat.
URY914
Jul 17 2009, 03:24 PM
The springs will put your eye out.
Dr Evil
Jul 17 2009, 03:32 PM
Wear safety goggles.
If it would help, I have a spare shifter that can be rebuilt for you and you can just swap it in. Let me know.
Dr Evil
Jul 17 2009, 03:42 PM
QUOTE(ellisor3 @ Jul 17 2009, 04:53 PM)
Yes
ellisor3
Jul 17 2009, 03:46 PM
QUOTE(Dr Evil @ Jul 17 2009, 05:16 PM)
I just checked with the bird, it is only available from Porsche of Germany, 2-3 month deliverly. So, yes I do need it, if you will PM me and let me know how much. The bird said the part no. was 900.309.010.00 and it should be a 6mm x 3mm roll pin.
I was just reading the instructions for disassembly of the shifter, may be easier to get a new one. I will get this pin replaced and new bushings and see how it works before I go there. Thanks again to everyone
ellisor3
Jul 17 2009, 03:48 PM
QUOTE(Dr Evil @ Jul 17 2009, 05:32 PM)
Let me know how much, that would be great.
Jul 17 2009, 08:57 PM
QUOTE(rhodyguy @ Jul 17 2009, 01:11 PM)
901
Dr Evil
Jul 17 2009, 09:35 PM
Andy has a JWest kit in there.
Jul 17 2009, 09:45 PM
QUOTE(Dr Evil @ Jul 17 2009, 07:35 PM)
Yes. But the part in question is bone schtock 901.
I still don't see the screw in his picture, but i concede to the eagle-eyed majority ...
James, apparently, your screw is fine!
Andy
