golfczar2
Jul 17 2009, 05:37 PM
Hello 914 group, I need help with this problem, which I have taken to two mechanics, (one of which owned a 914 at one time) and am still plagued by this problem. The car stars fine, runs for a couple of miles then cuts out. I can sometimes keep it running by goosing the pedal till it re-revs but sometimes it will stall and I have to pull over and re-start it. Once I pull over, and re-start , it may run fine for a while or the engine may immediately die again.
Here is what I have done so, which hasn't solved it but just depleted my 1975( l-tronic) 914 account.
Rebuilt intake air sensor
new auxillary air regulator
Rebuilt fuel tank and new fuel filter
mechanic tightened and soldered any loose wires found.
Any suggestions would be appreciated,
Golfczar
Ian Stott
Jul 17 2009, 05:41 PM
Mine was acting similar when I first got it and when I neatened up the wires around the coil and distributor it never happened again. Your problem seems to be a wiring related issue, I know your mechanic went over it and I may be wrong but that is what cured mine.
Ian Stott
Moncton
Canada
Millerwelds
Jul 17 2009, 05:48 PM
Recently had a similiar issue. Mine happened to be a pinched fuel line. Are you running a fuel pressure gauge?
Joe Bob
Jul 17 2009, 06:01 PM
Fuel filter.....
r_towle
Jul 17 2009, 07:54 PM
Fuel pressure regulator.
Its a rising rate one on the L-jetronic.
See what your idle fuel pressure is when cold.
See what you idle fuel pressure is when hot.
Two things could go bad.
The fuel pump could be dying...or the regulator could be dying.
Rich
