QUOTE(mikez @ Jul 18 2009, 11:46 AM)
Why don't you simply lower the front end......lot's easier....
Well mikez, I am trying to maintain SOME ground clearance., I am using 205-50 -15 tires...and the backup set of 195-60-15s are virtually the same diamenter/height....and I just don,t want to HAVE to install a steering rack,tie rod spacer kit to maintain a proper alignment/ front end geomentory (sp)....However the alternative, as you have pointed out, is to lower the front end. If I have to do this it will require a complete ,castor ,camber,toe ,ackerman effect, check on the front end alignment......more work I know, than stuffing in a couple of spring spacers.
