r_towle
Jul 19 2009, 07:54 PM
So.....
All you old school guys with all sorts of tricks up our sleaves, what type of clearances do you run on rod bearings when building a race motor?
Rich
Jake Raby
Jul 19 2009, 10:11 PM
What weight oil?? What journal diameter? What oil pump? Revs?
r_towle
Jul 19 2009, 10:46 PM
20/50, 2.0 liter stock, stock pump....up to 6k max
Mark Henry
Jul 20 2009, 08:20 AM
For me it's the run-out (like end play) of the rod big end on the journal, the tighter the spec and you will get better oil pressure. Many stock 2.0 rods I've seen are already past the stock tolerance, so check all your sets. Also will allow you to cut oil groves into the rod with less pressure loss. Some guys will radius the bearing a bit more.
Use quality bearings.
Jake Raby
Jul 20 2009, 09:38 AM
I would run .002 radial clearance on this, but thats not a recommendation!! I have been experimenting with all sorts of different clearances and I tend to keep the rods tighter than most people, but then open the mains up a tad more for better oil transition into the rod bearings.. Tight mains reduce oil volume to the rod bearings.
Things change when you start turning over 7K constantly..
ME733
Jul 21 2009, 10:28 AM
Mark Henry
Jul 21 2009, 04:25 PM
Melling oil pump
