Eric Taylor
Mar 6 2004, 07:59 PM
When I put the lead's on the pin's, i'm not getting anything. what am I doing wrong?
I'm following the pic on the bird board.
Eric
ChrisReale
Mar 6 2004, 09:30 PM
Not sure, but whatever you are doing, its wrong....
maybe your TPS is toast?
McMark
Mar 6 2004, 09:36 PM
You are moving the throttle plate right? Which pins are you touching? What size engine?
Rgreen914
Mar 7 2004, 03:04 AM
You need one of Bowlsby's neat plug adapters for setting the throttle switch; it makes the connections much easier.
Katmanken
Mar 7 2004, 11:23 AM
Got the test leads plugged in the right holes in the VOM?
I've done that one more than once....
Ken
