As I returned from Lime Rock last Saturday, I got to within 5 miles of home after the 400+ mile round trip, and I heard a banging noise when I downshifted for the traffic light. I had heard this before, a little while ago, and it turned out that one of the bolts that goes through the trans mount had fallen off, and the trans was baning against the body... I though this was happening again, so I slowly drove home, and looked underneath... the rubber had completely seperated from the trans mount... and the trans was only hanging from one mount...
I thought that with the rainy weather MASS is scheduled to have this week, I'd pull the trans, switch out the mount, and finally find out why my clutch slips from time to time. It's really weird, when it's cold (outside, not the car) no slipping... as the temps go up, the slipping comes and goes. When we left Lime Rock, I was having trouble climbing the hills leading to the highway... by the time I got to the highway, I could pull a rolling start in third with no slipping at all...
Anyway... here's where I have some questions for all the Trans/clutch gurus...
I found that the ball the clutch fork rides on had loosened up, and I sure it rotated from time to time... could this be where my slipping was coming from?? (not to mention, it was leaking) I also shot some pictures of the clutch and so forth... it looks like the clutch was not being completely mesched with the flywheel and pressure plate? Why do I have some shiney surfaces on the disc, and some not so shiney surfaces... what did I do wrong when I put the engine in last year??
ANY AND ALL HELP WOULD BE GREATLY APPRECIATED!!!
and now, the pictures...
You can see the leakage caused by the loose ball mount..
