JRust
Jul 21 2009, 09:42 PM
Just what my title says. My parts car has a nice windshield. How do I get it out without cracking it?
Joe Owensby
Jul 21 2009, 10:19 PM
I removed one by: First remove the trim. Then, take a wire (I used a guitar string), and insert through the butyl rubber. Then with someone on the other side of the wire, gently saw the wire back and forth around the perimeter of the windshield. I did this one day when it was hot outside, and the rubber cut fairly easily.
jt914-6
Jul 21 2009, 10:25 PM
Of course the first thing is remove the trim. The windshield should be held in with windshield butyl. Get a very strong wire, without insulation not as thick as "mechanics" wire. Like a piano wire type. Run it through between the glass and frame. Wrap the ends around a handle of some type. You and a helper can cut the butyl by using the wire as a knife.
Glass houses have a device that heats up and they slide it around the glass seal and it melts the seal enough to remove it.
Ask a glass house how they might suggest or what they would charge to remove it for you.....
sww914
Jul 21 2009, 11:55 PM
First- very important!
Make sure that you're not hungry or thirsty, you don't need to pee, there aren't any screaming kids or fighting dogs around, and that your blood levels of nicotine, alcohol, THC, caffeine, and anitdepressants are correct.
I use one of those new retracting blade utility knives, nice and thin.
Remove the trim, put a new blade in your tool and cut the butyl rubber from the inside, all the way around, at least twice. Don't push hard, the window should come right out when all the butyl tape is cut.
Drums66
Jul 22 2009, 01:55 PM
[quote name='sww914' date='Jul 21 2009, 10:55 PM' post='1193947']
that's a very good starting drill(LOL).......but I'll add one.
make sure your wife or girl is taken care of also!!
plymouth37
Jul 22 2009, 02:52 PM
Hire someone who knows what they are doing to remove it for you.
Last time I tried to remove one myself it came out in 1-2 million pieces, that may have just been operator error though.
Katmanken
Jul 22 2009, 09:42 PM
I've broken two with the original factory heat softened adhesive strip with the heatable wire in it.
That stuff is like a brick when it's not heated.....
JRust
Jul 22 2009, 11:27 PM
It was hot out which definately helped. I used a utility knife & just kept working my way around from the inside. The puddy/glue was soft & prety easy to work with. Success
. Other than the windshield being dirty it isn't pitted or cracked
. Nice OEM windshield for a backup
914four
Jul 22 2009, 11:53 PM
QUOTE(JRust @ Jul 23 2009, 12:27 AM)
Are all of your parts from your parts car for backup or are any for sale?
sww914
Jul 23 2009, 12:35 AM
Sweet!
I hope my zen suggestions helped.
JRust
Jul 23 2009, 01:39 AM
QUOTE(sww914 @ Jul 22 2009, 11:35 PM)
Sweet!
I was fairly loaded on Wild Cherry Pepsi. SO I think the caffeine level was good. The utility knife worked excellent also. Your tips worked perfectly
edwin
Jul 23 2009, 07:31 AM
unfortunately i broke my screen getting it out and i am based in Australia try finding a new one local.
on another car i knew the screen would be hard to get out so i got one of the best places in town to get it out. it shattered and still had to pay for the service.
after watching the "pros" do it i didnt feel so bad.
Edwin
