here's a story of a problem my car picked up last summer that in solving the problem myself should give everyone a laugh.
June of last year I pulled my car out of the garage and had it out in the yard just idling away. it had always run fine. All of a sudden, it started idling poorly. it would speed up then slow down. it kept doing this until if felt like it was ready to stall out.
As it was running poorly, I noticed the fuel pressure gauge swinging wildly from 50psi down to 25-30psi, and then back up again. over & over.
My first thought was a fault code in the Bosch controller but since my scan tool didn't read Porsche codes as I wanted, I looked to the basic fuel system for my fault.
First I replaced the FP regulator, $85 bucks, problem still there.
Then I decided to buy the Durametric software for doing full running diagnostics on Porsche vehicles only. $750.00 However, there is a problem. I don't have a laptop to install it on. Off to BestBuy. $650.00 there. The software says every system is running within normal parameters.
Next up I put a meter on my fuel pump to measure running voltage. The voltage is swinging up and down like the fuel pressure. 13v down to 9v and back up again.
Ah ha! alternator must have a problem.
Now I remove the alternator to get it check.
$40.00 to check it but OH! OH! now I notice that the dreaded 1995 993 engine wiring harness problem has made a home in my car
. $900.00 later I have a new harness.
I install it but the problem is still there.
Now I'm guessing a better fuel pump.
I get an Aeromotive unit and a 10 micron Aeromotive filter from Jegs $450.00 to replumb and relocate my current pump to the front trunk.
I get it all replumbed. the last thing left to do is pull the hose from the old pump an reinstall on the new one. I know I have about 1 gallon of gas left in the tank, and have the catch pan ready. I pull the hose off and barely nothing comes out.
I have a cheap ($6-8.00)Autozone clear inline filter between the pump and the tank, I decide to now pull the hose from the tank, an as soon as I do, gas pours out of the tank.
As I reconnect the fuel hose to the new fuel pump, pour clean gas in the tank.
fire it up, and last Saturday, I'm finally back on the road.
Since the economy took a dump last fall, I've been hoarding my money and scare to spend to much on anything for fear of losing my job. That is the reason this problem has side lined my car for a year now.
Expensive lesson learned here.
Hope everyone gets a good laugh at my expense.
Ron
