RiqueMar
Jul 23 2009, 01:33 PM
You might have seen it in my progress thread that I'm switching to side shift on my 70'.
Question: When switching to side shift from Tail shift, do you have to change that plate mounted to the firewall that the linkage comes through?
dr914@autoatlanta.com
Jul 23 2009, 01:42 PM
QUOTE(RiqueMar @ Jul 23 2009, 12:33 PM)
no just install the firewall conversion bushing
RiqueMar
Jul 23 2009, 02:22 PM
QUOTE(dr914@autoatlanta.com @ Jul 23 2009, 12:42 PM)
Damn. Not the answer I wanted to hear.
Is there a 'best' way to go about doing this?
Cupomeat
Jul 23 2009, 02:26 PM
Hmm, well I guess the "BEST WAY" is to
1. grind down/fill the firewall pivot
2. Cut an side shifter firewall to get the surround for the rubber boot
3. Weld the surround
4. Paint the area
5. Install a new side shifter bushing and boot.
Does that help? I am sure I can make it more complicated if you'd like
eric
tat2dphreak
Jul 23 2009, 02:43 PM
the conversion bushing isn't fun to put it, but it's better than the alternative...
soak it in HOT water for a bit before doing it
FWIW, even if you change the firewall piece, the other bushing isn't easier to put in...
RiqueMar
Jul 23 2009, 02:49 PM
"Conversion bushing" does this mean I don't have to change and weld in a new piece? Like an alternative?
JRust
Jul 23 2009, 03:02 PM
No you don't need to put in a different piece. I did this on my 70 & just got the right bushing. They are easy to put it. Put it in boiling water to get it a little pliable. Then add a little grease & it goes right in. I haven't figered a perfect cover for the area. I just kept the stock sideshift boot on there even though it doesn't attatch to the firewall. This change is well worth the time
RiqueMar
Jul 23 2009, 03:10 PM
QUOTE(JRust @ Jul 23 2009, 02:02 PM)
I'll go with that, as everything already looks good.
We do have a full shop and a fiberglass guy, maybe we can fab up a sort of boot for these type of conversions?
What's a good place for the bushing?
Cupomeat
Jul 23 2009, 03:25 PM
I've bought them from PP and AA, but you can probably get them locally in the So Cal area.
RiqueMar
Jul 23 2009, 03:45 PM
QUOTE(Cupomeat @ Jul 23 2009, 02:25 PM)
Is there an actual Conversion bushing? Or is it simply the one that is placed in the later models?
Spoke
Jul 23 2009, 04:10 PM
I just finished converting the flange on my 71 in prep for a sideshift tranny.
The pics below show what was described earlier:
1 Grind down the original flange
2 get a flange from a parted out sideshift chassis
3 Weld sideshift flange into place & paint
I just finished and haven't painted yet.
RiqueMar
Jul 23 2009, 04:24 PM
QUOTE(Spoke @ Jul 23 2009, 03:10 PM)
So it looks like the holes match up?
Is this the bushing that I just need to place in there?
Click Here
tat2dphreak
Jul 23 2009, 04:44 PM
that's the one!
much easier than the alternative, if you ask me.
RiqueMar
Jul 23 2009, 05:48 PM
QUOTE(tat2dphreak @ Jul 23 2009, 03:44 PM)
that's the one!
Cool, so it's just this, some boiling water, and we are in business.
Chris Pincetich
Jul 23 2009, 05:54 PM
You gots it now
That piece of plastic conversion bushing is the piece you need. Only metal work needed is if you want the boot/cover to fit correctly.
Have you dealt with the engine mount bar? Ya needs the one with the hole it in for the sideshift. Search for sideshift+conversion and my user name for a decent thread on the process from 2 yrs ago. I never did find that camera with the final pics
RiqueMar
Jul 23 2009, 06:11 PM
QUOTE(ChrisNPDrider @ Jul 23 2009, 04:54 PM)
You gots it now
No need for that search, I already have it.
biosurfer1
Jul 23 2009, 09:47 PM
I made a little tool that helps push the bushing into place (boiling water didnt soften mine very much)
its just a piece of all thread with two washers and nuts on each end. make sure the washers are bigger than the hole through the firewall and tighen down the nuts until it presses into place.
worked well for me
tat2dphreak
Jul 24 2009, 10:27 AM
I did the same thing as Brett... long bolt, nut and big washers="press"
I didn't know about the hot water at the time
Cupomeat
Jul 24 2009, 10:44 AM
As Bill Cosby might say here, Whever you are pushing something large out, you always need more hot water...
Jul 24 2009, 11:24 AM
Rand
Jul 24 2009, 11:32 AM
Yeah baby! Perfect excuse for an upgrade while you're there!
tat2dphreak
Jul 24 2009, 11:47 AM
yea, why get a $13 part when you can completely upgrade the system
don't get me wrong, if I had an extra 1k lying around, a rennshift+rear kit would be ideal
Rand
Jul 24 2009, 12:07 PM
Why bother with any kind of an upgrade?
Because they make things work better, go faster, increase the fun factor, etc, etc.
I love upgrades!
Of course, budget is always the thing that gets in the way of most of them.
tat2dphreak
Jul 24 2009, 12:41 PM
Of course, budget is always the thing that gets in the way of most of them. smile.gif
the good ones, anyway
94Timmer
Jul 24 2009, 12:57 PM
Hi Rique,
I did the conversion to side shifter on my '70 also, and did not have to change anything on the firewall. I did hhave to get the specific shift rods for it, and got new bushings and ball cups at the same time. I'm in the process right now of putting the correct end cover on the trans to get rid of all that extra stuff (and the potential oul leaks at the seals...
Good luck,
Tim.
RiqueMar
Jul 24 2009, 02:17 PM
QUOTE(94Timmer @ Jul 24 2009, 11:57 AM)
Hi Rique,
Good luck,
Tim.
As for the kit, I do plan on getting it, I just want to drive mine first so that I know the difference between regular and a sort of upgrade.
ClayPerrine
Jul 26 2009, 09:46 PM
If you are looking for a CSOB shift improvement, here is one that will only cost most 914 owners a little labor.
Click to view attachmentI used the U-joint and shaft out of an old steering linkage. Those U-joints last forever, and most 914 owners have a bunch of them laying around.
This is on Betty's car. It had a stock coupler, but a couple of welds were breaking loose, so I had to take it apart and fix it. I could not get that @#$# cone screw out! So I devised this, inspired by the J-West linkage. It is NOT as good as was James Adams sells, but it is a substantial improvement over the stock nylon bushings.
And best of all it was FREE!!!
jt914-6
Jul 26 2009, 10:04 PM
A friend used the steering coupler on his 914 race car and it worked out really good.
A pic of my "homemade" bushing tool.
Dr Evil
Jul 26 2009, 10:06 PM
Thats interesting. I would wonder if without the cone screw it would rotate slightly over time. Even though, I think I will give that a shot sometime
I bet I can drill and tap the collars to utilize a cone screw.
ClayPerrine
Jul 26 2009, 10:16 PM
QUOTE(Dr Evil @ Jul 26 2009, 11:06 PM)
Why would you need the cone screw???? The steering shaft ends that are welded into the tubes are splined and are notched for the bolts to pass through.....
Dr Evil
Jul 26 2009, 10:58 PM
The ends of the shafts are splined? Not that I recall. You sure?
Dr Evil
Jul 26 2009, 11:24 PM
Also, would not the brass bushings for the U joint have the same/similar effect?
ClayPerrine
Jul 27 2009, 07:23 AM
QUOTE(Dr Evil @ Jul 26 2009, 11:58 PM)
Doc... 'cmon.... The U-Joint was salvaged from the STEERING linkage. Do you really the engineers at Porsche would want it to slip in a circular motion?????
I removed the existing end for the shift coupler and rear shift rod, cut the splined ends off the steering rod from under the dash and welded them into the shift linkage tubes. The U-Joint is a bit longer than the old coupler, so I had to shorten the rear tube some to get it to fit.
I also went to the hardware store and bought brass bushings to replace the bushing in the side shift console.
Dr Evil
Jul 27 2009, 08:19 AM
QUOTE(ClayPerrine @ Jul 27 2009, 09:23 AM)
Ah, you cut and welded the steering splined ends
I thought you just clamped the things to the shafts
