I seached high and low. Do we have a thread on this somewhere? I have four flares from performance products as well as 2 flared rocker panels-unknown manufacturer. I taped the flares in place and used the rocker panels as a reference for the flares on each side. I know this is fiberglass, but the front flares that I have are wider than the stock opening at the bottom corners of the fender (viewed from the side of the car left and right of the front tire). About 3/8". This seems to be okay because the rockers are about 3/8" shorter than the length of the stock body they fit under. The rear fender flares are almost identicle in measurement in opening at the lower edge to the stock bodies. Is this correct for left right orientation? How do you figure the verticle location of the flares? Do I just use the bottom of the flare and line it up with the bottom line of the body? I also saw on one post one of the guys said when cutting the metal don't cut straight down, use that to support the bottom edge of the flare.How did you guys set them up and cut?
FWIW I will be riveting these flares on. I do not have jack posts on the car.
