I've got a nice new heavy ducktail I purchased from a member in the classifieds section here and a glass trunklid from another member. Turns out the ducktail is probably heavier then the trunklid and the lid is ultra thin (read that as trunklid 4sale). Milt (aka Zeke) and I agree that there isn't enough material on the trunklid to reliably blend the two. His thought is you need to dish out some material on the trunklid to get a good bond/transition between the two and there just isn't enough there to dish out.
Anyway, is it possible to bond/glass the ducktail to a stock steel trunklid and expect that it will hold up even when exposed to heat over time? Milt believes this would eventually cause the joint to crack and I tend to agree since the CTE mismatch between the two would inevitably cause the joint to fail.
Anyone have real experience with this over time? What method did you use to join the two?
Kev
