John2kx
Mar 7 2004, 07:51 AM
Howard,
I run a Renegade cooling system and have had overheating issues along the way. Most were due to problems caused by myself. I'll post some pics of my system and be glad to share what I have learned the last year and a half.
First pic is of water sender location. I actually run two gauges. The two brass fittings are my temperature monitor points. Since the water from pump is routed into block, to heads and then to intake prior to moving back to radiator, the intake is the preferred location of sender.
John
John2kx
Mar 7 2004, 08:16 AM
This is the thermostat of choice from what I have used. Note the 1/8" bleed hole. This will allow removal of air when filling system as well as protect water pump impeller from damage while thermostat is closed. Note: I drill three of these 1/8" holes in mine and use a 180F. Available through Jeggs or Summit.
http://photos.groups.yahoo.com/group/pors-...rc=gr%26.view=tJohn
rick 918-S
Mar 7 2004, 09:25 AM
Your link isn't working. Just post the pictures you big tease!
steve@ottosvenice.com
Mar 7 2004, 09:37 AM
Frist thing is to make sure All of the air is out of the system Raise the front of the car up about 18 inches the run the motor and open your bleeder valve on the Rad . this will allow any air pockets to move up to the rad avd be removed. Steve
John2kx
Mar 7 2004, 09:38 AM
Howard,
A more detailed description of your temperature readings would be helpful.
-Are you seeing 240 while on the road above 40 mph? Or does the temp. creep up in traffic and then never come below 240 after getting back to cruise mode?
-What size is your inlet/outlet holes for radiator? A picture would be helpful here.
-How do you bleed air from cooling system? Where is petcock located?
-Do you have a recovery tank? Is the level in tank always the same when car has sat overnight? (looking for a leak here, ie, headgasket, intake etc.)
-Have you tried running both fans continuiously from warm up (170F) and left on during a hot lap? (trying to see if your system is playing catchup)
-How are your water hoses routed? (under car, through longs.)
-Any kinks in hose? Inlet to water pump is a common area.
John
Mar 7 2004, 10:54 AM
Front tank and Rad
Mar 7 2004, 10:58 AM
We are building a Beach Boys Monterey this is a 5.0 Ford built to 400hp that is going in it. Steve
BIGKAT_83
Mar 7 2004, 11:39 AM
Sure looks like alot of obstacles to overcome to use that Ford engine.
Bob
BIGKAT_83
Mar 7 2004, 11:49 AM
QUOTE(John2kx @ Mar 7 2004, 06:16 AM)
t/s.http://photos.groups.yahoo.com/group/pors-chev/vwp?.dir=/66+912+V-8&.src=gr&.dnm=HighFlowTstat.gif&.view=t&.done=http%3a//photos.groups.yahoo.com/group/pors-chev/lst%3f%26.dir=/66%2b912%2bV-8%26.src=gr%26.view=t
John
John is this the photo you wanted.
Bob
John2kx
Mar 7 2004, 12:07 PM
Bob,
That's the one, thanks!
John
John2kx
Mar 7 2004, 12:19 PM
Howard,
Here's the link to a thread I forgot about. You should learn something from the info here.
http://www.914world.com/bbs2/index.php?act...thermostat&st=0John
Howard
Mar 7 2004, 07:36 PM
To all and John especially. Wouldn't have even considered another 914 without this site. The info is invaluable.
Read all the stuff on the link (it should probably be nailed as the start of a V8 sub board). Purged bubbles, took it for a blast, then let it idle for 5 minutes. Shut down and let it cook for another 5. Using a candy themometer, took Zora's temp. Dash gauge says 245, top of radiator petcock 179, expansion tank 195. Engine does not even feel especially hot to the touch. Think I may be getting a bare metal reading.
Two sensors..see below. What is all that plumbing? BTW, has two fans blowing down from engine hatch opening. Keeps dipstick from getting too hot
but just noise besides that. Do we think it does any good?
Hope these post OK.
914-8
John2kx
Mar 7 2004, 08:22 PM
Howard,
Your pics posted fine. Some took a long stare to figure out what I was looking at........suggest in the future starting with a overview of area your trying to pin and then zooming in a bit for the next shot.
Good news! Your cooling system looks better than most I've seen that weren't designed by RH.
1. I only notice one fan up front and thought you mentioned one (of two) staying on all the time and the second was manually controlled. Am I missing something here? I would like to understand for sure what turns your front fan on. Trace the wiring from fan motor. You should see power source and if supplied with a thermo switch mounted in radiator, a second set of wires from this switch to fan motor or to a relay or similar device that connects back to fan motor.
2. I think you have a source of air entering your system the way things are configured. The expansion tank mounted in left rear of engine bay is a good fill point, holds lots of water and is mounted higher than radiator and intake.......all good. What I see wrong here is that if you fill that tank full when car is cold, as water temperature rises and expands, there is no place for excess to go but out overflow line. I see no overflow tank and it appears overflow line discharges to ground. What you want is a tank for the water to discharge into and then as water temperature cools (contracts) a vacuum is started that will suck water from overflow tank back into expansion tank. Without overflow tank, when vacuum occurs, you will suck air back into system everytime you run through a heat/cool cycle. I believe for less than $10 you can fix this problem. Note: I usually see about 1 qt. of water added to my overflow tank when car is hot.
I'll attach a pic of how Renegade (RH) makes this happen. The small fill port acts just like your large expansion tank. The plastic tank is the overflow collection point. Note: overflow tank is mounted as high as possible and close to expansion tank to eliminate air pockets from enter cooling system.
I don't think the fans mounted to engine bay help. They can't hurt and are already mounted. Up to you if you want to remove them.
Sensors: the picture was dark but what I see is tapped into a oil source near distributor. I have something similar but use a single sensor with two outputs. One for oil pressure gage, the second goes to idiot light. Look at front of intake (either side of thermostat housing) for water temperature sensors.
I would not put much faith in measuring exterior of radiator, thermostat housing, hoses etc. when trying to determine true water temperature. My experience with a $175 infared gun measuring these points proved useless. To prevent risk of damaging that new engine, I'd advise a second method of reading true water temperature.........buy another gage.
You should have found how to bleed system of air from previous posts. This is often overlooked by most but a important part of procedure to ensure air is removed.
John
John2kx
Mar 7 2004, 08:39 PM
The attached pic should show how air is kept out of system on my car when water contracts. Device with radiator cap would serve as your expansion tank. Plastic tank is overflow tank and the part missing in your system. Clear plastic hose is connected at bottom of overflow tank. Black hose is overflow line which discharges overboard.........I have yet to have that happen yet.
BTW, Scott at RH advises against radiator caps with the spring release handle. He does recommend using a 16 lb. cap with his system.
Hose routing: I failed to identify yours but would need better pics to do so. I recommend starting at your water pump. The one large hose there is suction side from radiator. From discharge of water pump, you will see flow to front of block, thermostat housing is outlet back to radiator. To and from expansion tank should make better sense after learning the basics. Hope I answered all your questions.
John
Howard
Mar 7 2004, 08:42 PM
John, as you said this is kind of like private emailing back and forth but agree group could benefit.
PO says 2 radiators in tandem. Haven't had front cover off but can hear one fan in front of radiator (s) that can be manually activated, no thermo switch found. Second fan behind radiator runs when ignition is hot, no switch there.
Will do the 2nd tank ASAP. Good idea. Can it be mounted as high as current tank or do we need gravity feed? Thing has not cooked over anyway, so really expect bad gauge/sender.
Sensors..goes to show you how much of a mechanic I am. Will keep looking for sender. There are elec tabs on radiator, but not hooked up nor wires present.
Temp check. Stuck thermo in expansion tank coolant and open radiator petcock. It's digital and pretty much instant.
Can you get me out at the National???
Howard
Mar 7 2004, 08:45 PM
Guess I should have waited for the picture.
New cap on list for tomorrow. Say, why don't you just fly out here? I'll buy
John2kx
Mar 7 2004, 09:02 PM
QUOTE(Howard @ Mar 7 2004, 06:42 PM)
Overflow tank should be mounted as high as possible. You don't need gravity since vacuum will pull the water back into system..........you just don't want a really long run or 2+ feet elevation difference between the two tanks. The plastic tank you saw in my picture can be purchased at many local auto part stores. Comes with mounting device, cap and hoses for less than $10. There are usually two sizes available.
If you removed your radiator cap shortly after engine temperature read 260F and measured water temp. in expansion tank with a good gage, I would point at your water gage too.
I have seen high temperatures without boilover.
How many tickets do you need : )
John
Howard
Mar 7 2004, 09:45 PM
John, we have to work on this communication thing. I don't want tickets, get me a starting time
. Watching golf is like watching sex. The pros may be better but I'd just as soon stumble through it myself
OK, now where were we. Here's the water pump. Looked all over engine top for any other wires and finally found temp sensor (pic to follow).
Howard
Mar 7 2004, 09:47 PM
OK, this can't be right. Temp sensor nestled between exhaust ports? No shit it's hot! Is this a normal location? Looked around thermo housing, no wires there and pulling this turned of the gauge.
Howard
Mar 7 2004, 09:56 PM
oops! can't seem to add picture
Howard
Mar 7 2004, 09:59 PM
And oops again. Forgot to shrink!
campbellcj
Mar 7 2004, 10:34 PM
QUOTE(Howard @ Mar 7 2004, 07:45 PM)
I have to admit I have no idea what you guys are talking about with this water-pumper 914 stuff
...but that quote is hilarious!
Howard
Mar 7 2004, 10:38 PM
Chris, didn't know you played golf
Brad Roberts
Mar 7 2004, 11:35 PM
His radiator is a RH setup from the early/mid 90's. It is two 3 core radiators setup as a double pass unit. The water flows through the front 3 rows then through the back 3 rows. It uses a Corvette electric fan and a VW rabbit thermostat switch for the fan.
IF.. the pics posted here where of his car...
B
BIGKAT_83
Mar 8 2004, 12:03 AM
Howard when I looked at the pictures of your car on Ebay. The cooling system was a early Renegade. It is two radiator cores one in front and one in the rear and a double pass system with the water going to the front core first and then to the rear. If you look you can see that the common tank is on the left. I had one of these in my car at first and it cooled great. This is really a good radiator and should cool your car fine.
With the temp. sender in the head its going to read hotter than if it was mounted on the intake by the thermostat.
What kind of Heads and headers are on your car? I can see that the headers are for spread port head and it looks like a adapter is used for a standard head. This is really a good thing you don't see these everyday.
Lets see some more pictures of the radiator and how the thing is plumbed up.
Bob
Brad Roberts
Mar 8 2004, 12:04 AM
Funny.. that is what I said...LOL
B
BIGKAT_83
damn I type slow........
Brad Roberts
Mar 8 2004, 12:10 AM
I'm just happy you are contributing. I'm seriously thinking about a V8 conversion area on the BBS. I have customer cars in the shop right now that have NO idea where to turn too for minor tweaks/issues that may arise during their ownership of converted cars. The common denominator they all have: web access/hate email groups/own V8 914's. humm...
B
John2kx
Mar 8 2004, 03:11 AM
QUOTE(Brad Roberts @ Mar 7 2004, 10:10 PM)
B
Brad,
I think that is a good idea. From what I see, most of the V8 guys tend to lurk more than contribute and understand why. I've gotten over it and don't mind mixing things up.
A separate V8 section would make it easier for the newbie to find information specific to his car.
John
Howard
Mar 8 2004, 09:58 AM
John, Bob, Asshole...
Obviously, not sure what I've got here, but do have a file folder full of receipts. Will go thru them to look for some key words on motor.
Back to sender. Should I just get another sender and put in intake manifold? Current one is useless, as it goes right to 240 and sits there. Fan, no fan, warm day, cool night, at speed, at idle, in traffic, 10 minutes after shutdown, it's 240.
Anyway, will remove cover and try to get some better rad pictures. As far as heads, engine specs and such, send in the experts. Headers are beautiful jet coated thingies that sound great, but don't know much more as of now. Someone local know this shit?
Brad, is this how you got your nickname?
BIGKAT_83
Mar 8 2004, 12:23 PM
Howard I didn't see your first pictures that you linked to on your post. That radiator is just as Brad and I said. That thing will cool your car.
After looking at the pictures It sure looks like a well built car all an fittings on the water pump and those headers look great. If the rest of the car is like the few pictures on you web page you got a hell of a deal.
Bob
John2kx
Mar 8 2004, 04:01 PM
Howard,
I'm with Bob, you got a deal! I'd hate to admit what I have in my car and still need to paint.
Yes, I would just buy another water gage and install on intake. The pictures I included that showed top of my motor are the most common places to mount sender. You should have at least one mounting position on either left or right side of thermostat housing. Look for a pipe plug about 1/2" in dia.. Note: buy a matched set (sender and gage) as you don't know which part of your system is bad.
I prefer the mechanical gage. It takes a little longer to snake the larger tube from front to back as opposed to a thin wire, but the readings are accurate and instantanious. I recommend the Autometer 2-5/8" mechanical #105-4433 from Jegs (1-800-345-4545) or similar for about $75. It comes with 12' of tubing necessary for routing in a 914 and you can easily mount under dash, in center of car for easy viewing.
Look forward to reading about your results.
John
Howard
Mar 8 2004, 04:28 PM
Thanks for the advice and kind words.
Will keep you posted on updates and new questions.
Howard
Mar 10 2004, 09:35 AM
Latest comment from 'knowledgeable' Chev mechanic.
Later V8's have the temp sensor in the head, right between the exhaust ports. Hottest spot in engine, and 240 is 'nominal'.
Gauges on stock cars don't list degrees, just C to H. He said to get one of those and don't panic. Did show me aftermarket replacement that goes up to 270. Is this all BS???
boxstr
Mar 10 2004, 10:34 AM
My current V8 has two h20 temp gauges, one is a regular h20 temp gauge reads up to @220??? I will have to look, the other is an oil temp gauge that reads up to @310 ?? Both are mountd on the dash one in the ashtray hole and the other where a radio used to lurk.
CLINCAMP9148
BIGKAT_83
Mar 10 2004, 10:36 AM
QUOTE(Howard @ Mar 10 2004, 07:35 AM)
Howard he is right. Thats what I said in one of my post. I went thru this with a freind. His car would read about 30/40 degrees hotter than the gauge in the intake.
Howard
Mar 10 2004, 11:01 AM
Thanks, needed moral support, guys. Don't know if true, but for all you really old pharts...
Ford came out with the V8-60 in the early thirties. The '60' was the 60mph brag for top speed, something unheard of in an economy car.
The story goes.. A guy buys one that won't go past 55. Takes it back to dealer several times without satisfaction. Deal ends up on Henry's desk. Memo from him to dealer: Adjust speedometer, dummy.
I don't need no estinkin' gauges!
Brad Roberts
Mar 10 2004, 05:21 PM
Howard,
I was not actually trying to be an asshole at that point. I could'nt tell who was posting pics of whose car. I knew you owned one...
B
Howard
Mar 10 2004, 09:17 PM
Holy shit, Brad. Don't go sensitive on me. Ragging you is the only way I can pay you back for the great advice.
