I've only had the car a few days and don't have another 914 handy for comparison, so thanks in advance for your help. Here goes...
1.) When the windows are fully up, they do not meet the side seals on the hardtop...mostly at the forward edge. I'm guessing this is probably due to shrinkage of the side seals and I should replace them?
2.) The rear seal on the top...the "U" shaped one that contacts the roll bar is pretty crapped out. I'm going to replace it. There's also some kind of foam tape stuff on the roll bar where it contacts the seal. I'm guessing this was an attempt by the previous owner to make that crappy top seal work, and I can take that off when I replace the seal. Am I correct?
On another note, the rear window...did they have gaskets or are they simply "glued" into place and sealed? Mine looks like it was done by a drunk with some clear silicone sealant.
Ken
